Old 10-09-2014, 01:51 AM   #21
apbright
apbright's Avatar
Default Re: mitchell over drive
I have a slightly stronger opinion. Here in the Bay Area, Freeway driving and hill climbing are part of daily life, if you're going anywhere other than to the corner store. Before I had the Mitchell OD (standard 26%), that meant much engine lugging or uncomfortable/disconcerting over-revving. Adding the Mitchell OD transformed my Model A from a curiosity to downright usable transportation. (Though I do try to remember someone's quote that, in a Model A, 'Drive no faster than your angels can fly')
apbright is offline   Reply With Quote
Old 10-17-2014, 12:50 PM   #22
mrphil
I installed one in my 29 Tudor. I love it, but if I do it again, I would choose the 20% reduction rather than the 30% reduction.
mrphil is offline   Reply With Quote
Old 10-17-2014, 01:20 PM   #23
Tom Wesenberg
Tom Wesenberg's Avatar
Do you have the 5.5 head? That helps a lot. Also you need a good cam.
Old 10-17-2014, 05:53 PM   #24
Synchro909
Synchro909's Avatar
Tom is right about a high compression head. I have a Mitchell in 3 cars. One with a stock engine - OK but not getting the full benefit of the O/D. The next has 5.5 head and downdraft carby - much better. The third has 5.5 head, downdraft carby and a touring cam - really excellent.
A note here for anybody new to these O/D's. When starting cold (say, first thing in the morning) do at least 2 miles before you try to engage the O/D. The oil needs time to warm a little or the synchro will lock you out of gear. (I use the oil recommended by Mitchell) A minor thing but worth remembering if you are to get the max enjoyment out of it.
I wouldn't be without one now that I have experienced them.
Old 10-23-2014, 07:54 PM   #25
Y-Blockhead
Y-Blockhead's Avatar
Does Mitchell have a website. Can't seem to find one...
Old 10-23-2014, 08:34 PM   #26
tbirdtbird
no they do not
'31 180A
tbirdtbird is offline   Reply With Quote
Old 10-23-2014, 08:47 PM   #27
Mike Peters
Mike Peters's Avatar
How about rear end ratios with a Mitchell? Should we go with the standard 3.78:1 or should we drop back to a 4.11:1?
Mike Peters is offline   Reply With Quote
Old 10-23-2014, 08:58 PM   #28
Tom Endy
Tom Endy's Avatar
The Mitchell overdrive is 26%, pretty well suited for a 378:1 ring & pinion ratio. The Borg Warner overdrives were 33% and it was too high for a 378. This is where the 411:1 ring & pinion was better suited.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 10-23-2014, 09:51 PM   #29
Mike Peters
Thanks Tom. I've got an old Borg Warner in our 28 Tudor and I wish I had went with a 4:11 rear end. I once installed a 3.25:1 ring and pinion in a 35 Ford. Big mistake. Pulled too hard. Then I found a set of 3.78 gears for the 35, installed them and have been happy ever since. The car came originally with 4.11's and it was too slow. I may eventually buy a Mitchell for the 28. The Borg set up is not very user friendly, although it's worlds better then nothing at all.
