10-22-2014, 10:33 PM | #1 |
Installing the Hub Caps on 1928 and 1929 Model A's
Is there any Simple Tricks to installing the Hub Caps???
I bought 5 of the Stainless Steel ones and would like to install them on tight. With the wheel removed I bent 6 of the Tabs using a screwdriver and rubber hammer. The cap won't fall off but it is still a little lose. |
10-23-2014, 12:33 AM | #2 |
Re: Installing the Hub Caps on 1928 and 1929 Model A's
I add a bit of clear silicone calk, just 3-4 good dabs of it. I also like to index the Ford Script with the valve stem on top. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
10-23-2014, 09:16 AM | #3 |
I use the rubber o rings from mikes or snyders. I have no problems.
10-23-2014, 09:18 AM | #4 |
they need to be put on with wheels off . you can bend the tabs that way .
V4f |
10-23-2014, 10:13 AM | #5 |
10-23-2014, 10:49 AM | #6 |
10-23-2014, 10:59 AM | #7 |
"Someone" makes a press tool that forms the tabs into a different configuration, that allows the cap to "POP" on & off.
Bill W.
10-23-2014, 02:51 PM | #8 |
I bent over four tabs and used a little silicone. They are tight and have not fallen off or loosened up in forty years.
10-23-2014, 03:13 PM | #9 |
I haven't seen one of these for the 28-29 hubcaps, only the 30-31.
10-24-2014, 09:06 AM | #10 |
I get 4 tabs as tight as I can and then wipe silicone "instant gasket" round the joint between cap and wheel. It's invisible and stays rattle-free indefinitely.
10-24-2014, 10:21 AM | #11 | ||
Mike's A-Ford-Able has the one for 30-31. Expensive but works fantastic!! No silicone or rubber bands needed... |
10-24-2014, 10:53 AM | #12 |
They must have changed the 28-29 hubcaps since the last set that I bought. The 28-29 hubcaps used on 21 inch wheels snapped on tightly. I know that the repro 30-31 hubcaps used on 19 inch wheels haven't been snap on type at least since the 70s . There is an expensive tool for converting the 30-31 hubcaps for snap on use., I have no problem bending the tabs on the repro 30-31 hubcaps with pliers so that they will snap on and off. I'm yet to see a 28-29 hubcap that doesn't snap on. I haven't bought any new 21 inch style hubcaps in a while and still have a couple of sets on the shelf that snap on.
10-24-2014, 11:13 AM | #13 |
30-31 Hub Cap Tool ($58 @ Mikes)
