03-12-2020, 05:55 PM | #1 |
Gaskets
What are the best intake & exhaust gaskets to use?
03-12-2020, 07:31 PM | #2 |
Re: Gaskets
I've used the attach gasket, pricey, yes but worth it. never had to replace it never had a leak
JB http://catalog.remflex.com/FORD_Head...ket_p/3040.htm
Connoisseur of Rust |
03-12-2020, 07:58 PM | #3 |
Re: Gaskets
The only gaskets we use in this location are this type;
https://www.snydersantiqueauto.com/P...earchByKeyword Along with gland rings.
03-12-2020, 09:12 PM | #4 |
Re: Gaskets
If your not building for fine point the use of a quality sealant with off the shelf gaskets works well,permatex ultra gray,threebond,ect.
03-12-2020, 11:51 PM | #5 |
Re: Gaskets
I use late '31 2 piece copper gaskets, no sealant. And manifold glands when the manifold isn't drooping. I torque the nuts to 30 ft/lb and recheck after a couple of heat cycles.
Edit; Like the ones redmodelt links to.
The Master Cylinder Enjoying life at the beach in SoCal... Last edited by The Master Cylinder; 03-13-2020 at 12:09 AM. |
03-13-2020, 07:49 AM | #6 |
Re: Gaskets
03-13-2020, 10:30 AM | #7 |
Re: Gaskets
I also use the two piece copper clad manifold gaskets
03-13-2020, 11:51 AM | #8 |
Re: Gaskets
Had problems with an inexpensive gasket kit. The exhaust gasket was made out of something stiff, hard, almost brittle, was tan/light brown. Only lasted 25 miles before it blew a hole through it . Replaced with copper and OK. Took a picture, sorry can not find it
03-13-2020, 12:01 PM | #9 |
Re: Gaskets
My engine builder used the one piece steel gasket. Seems to work well, that's what was on the old engine for years, not problems. Only gaskets I've heard people have trouble with are the ones 30 closed cab is talking about I think although I've always seen them in green.
03-17-2020, 12:57 AM | #10 |
Re: Gaskets
Jerry in Shasta,
Thanks for the heads up on the Remflex gaskets. We use them on all the small block Ford Stroker motors we build and send out. Since we've been using them we've had no header leaks.... Summit racing has the 3040 gaskets for $29.11 Thanks again. |
03-18-2020, 10:18 PM | #11 |
Re: Gaskets
Gland rings are very important to keep the gaskets from failing. Do a trial fit first with just the gland rings to be sure the manifold will seat up to the block. Some times, the gland rings need to be made a little thinner so the manifold will fit up to the block. My experience, Chris W. |
03-18-2020, 10:23 PM | #12 |
Re: Gaskets
I also use the copper clad two piece
03-19-2020, 09:12 AM | #13 |
Re: Gaskets
i really like the copper ex / in gaskets
V4f |
