10-27-2010, 10:20 PM | #1 |
fuel pump removal from an 2005 sable
Can someone direct me to instructions on how to remove the fuel pump in a 2005 Sable. Thanks. coup34
10-27-2010, 10:51 PM | #2 |
Re: fuel pump removal from an 2005 sable
Pretty sure its in the gas tank, part of the fuel sender assembly.
So you either have to pull the tank, or maybe theres an access panel under the seat/ carpet/ trunk mat directly above the unit. Not sure if Ford still does it, but they used to have impact fuel cutoff switches in the cars..sometimes they would trip from tapping a curb or hitting a big pothole..look in your owners book to see if you have one.
I have So Cal rust free parts for 50's-70's Fords and Mercs..Trucks too. Send a PM with needs |
10-31-2010, 12:38 AM | #3 |
