Old 12-03-2016, 01:11 PM   #1
jwaldrich
jwaldrich's Avatar
Default Brake Rods
Did the brake rod support brackets ever have grommets? When I drive into town there are two bumps in the road that cause my rods to rattle something fierce!
John from Kapowsin
T&A Guy
jwaldrich is offline   Reply With Quote
Old 12-03-2016, 04:36 PM   #2
Barber31
Barber31's Avatar
Default Re: Brake Rods
Ive taken 2 good drives now that things are back together on my '31 and I too have noticed my brake rods rattle on good size bumps. I'm going to look into some kind of material that will cut down on this vibration. Does anybody know if the '32 grommets will fit?
Barber31 is offline   Reply With Quote
Old 12-03-2016, 09:23 PM   #3
Jim/GA
Jim/GA's Avatar
To stop the rattles, bend the springs into a tighter U shape so that they keep the rods under tension.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 12-09-2016, 09:43 PM   #4
Doug in NJ
Doug in NJ's Avatar
I found that the late-style wire springs worked a lot better than the flat ones.
They don't tend to lose their springiness.
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 12-09-2016, 10:11 PM   #5
Larry Jenkins
Doug
And, they return the brake pedal better..
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 12-10-2016, 07:10 AM   #6
RonC
RonC's Avatar
These are not Model A authentic but later Ford. You can use them on the Model A
http://www.macsautoparts.com/early_v...rd-372939.html
RonC is offline   Reply With Quote
