Old 10-17-2016, 08:03 AM   #1
krzewinskibe
krzewinskibe's Avatar
Default Progress worth showing
Working on my 1929 Tudor. Been in my wife's family since day 1...
Starting pic in my avatar. Stripped it down to frame Labor day weekend. Blasted and painted the frame and front suspension, rear suspension, rebuilt the brakes, had the wheels powder coated and assembled the roller this weekend.
Engine is at Schwalms...probably another 3-4 months lead time. I've already rebuilt the trans/torque tube.
Not too bad for progress for 6 weeks (wife and I have logged ~220 man hours so far)
working the on the body now....
will be vagabond/rock moss green when done. Hoping to have it out by memorial day
1929 Tudor
krzewinskibe is offline   Reply With Quote
Old 10-17-2016, 08:14 AM   #2
1930artdeco
1930artdeco's Avatar
Default Re: Progress worth showing
Looking good and I hope you have a heated garage. Those Maryland winters can be mean.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 10-17-2016, 08:20 AM   #3
frank mcdaniels
frank mcdaniels's Avatar
Make sure to check if the frame is sagged any. It looks good in the pictures. Some guys forget to do this. Now is the time to do it. Looks like your having fun. Frank
frank mcdaniels is offline   Reply With Quote
Old 10-17-2016, 08:27 AM   #4
krzewinskibe
My corner measurements prior to disassembly were pretty close (1/2" IIRC) and I didn't see any evidence of sag....but good call...will double check. Did have a busted front spring that I found afterwards.
1929 Tudor
Old 10-17-2016, 08:28 AM   #5
krzewinskibe
Mike
I mostly insulated it and have a propane burner I run in the winters...
Finding windows of opportunity for paint is my biggest concern...needs to be 60 deg....
1929 Tudor
Old 10-17-2016, 08:49 AM   #6
C26Pinelake
Good luck and have fun! You have a great start. Wayne
C26Pinelake is offline   Reply With Quote
Old 10-17-2016, 12:42 PM   #7
Marvin/TN
Send a message via AIM to Marvin/TN
It really should be 70 F or above to paint, Read your application guide for your brand of paint.
Marvin/TN is offline   Reply With Quote
Old 10-17-2016, 12:48 PM   #8
krzewinskibe
I have the 60-70 F reducers/activators
1929 Tudor
Old 10-17-2016, 01:19 PM   #9
Licensed to kill
Licensed to kill's Avatar
Looks great. Am working on the frame of my '31 DD. initial measurements put it out by 1/2" on the diagonal front to back but dead on back to about the spare tire holder. Looking down the rails, I could see that the frame was pushed to the right (pass side) by about an inch or so, so I pulled it back from that point and now all diagonal measurements are dead on. Checking for sag I found about 3/32" sag right at the motor mounts (as expected) and brought that up to level. I wasn't too concerned about that little bit of sag but didn't take much to take it out so. The side to side bend was a must to straighten out though of course.
Licensed to kill is offline   Reply With Quote
Old 10-17-2016, 02:00 PM   #10
Doug in NJ
Doug in NJ's Avatar
Looks good! I remember my car being in that state.
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 10-18-2016, 06:01 AM   #11
krzewinskibe
I laid a piece of 1" chromemoly tube down the length of the chassis....pretty darn straight with a max gap of 1/16" at the most. Not even worth messing with IMHO. Body panels were straight when I disassembled too
1929 Tudor
Old 01-01-2017, 05:29 PM   #12
krzewinskibe
Woohoo...significant progress to show.
Ora (schwalms) finished the engine WAAAAYYYY ahead of schedule. Mated it up to the transmission I freshened up and got it in the chassis today
HUGE change from this picture I took Sept 5
1929 Tudor
Old 01-01-2017, 09:24 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
Nice improvement. No grass grows under your feet.
Old 01-01-2017, 11:36 PM   #14
Beauford
That is AWESOME!!!
Beauford is offline   Reply With Quote
Old 01-01-2017, 11:49 PM   #15
al's28/33
al's28/33's Avatar
GREAT project...keep it in the family another 90 years!!
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 01-02-2017, 07:42 AM   #16
George Miller
George Miller's Avatar
1/16 is to much. You will find the other side might be ok. That will cause a twist which will mess up your hood fit. Now you are going to have compound angles. Remember as the cowl rises the top of the cowl is going to be off more than 1/16.
Most Model A,s have frame sag, I see it all the time when looking at Model A's. Most of the time it shows up as a uneven gap at the back of the hood on the driver side.
George Miller is offline   Reply With Quote
Old 01-02-2017, 08:06 AM   #17
Great Lakes Greg
Great Lakes Greg's Avatar
Steady forward momentum, as I like to say. If you and the missus hustle, you can make it by Labor Day. Keep us updated.
Great Lakes Greg is offline   Reply With Quote
Old 01-02-2017, 08:34 AM   #18
Terry, NJ
Terry, NJ's Avatar
Did you mean that your corner to corner measurements have only a 1/2" difference? That's quite a bit. Mine was about a 1/8" and I was worried. If this is the case, I would go back and check it again from slightly different points. With a broken front spring and a 1/2" error, out of square, it sounds like the car took a hit at some time in the past. This seeming small error can play havoc with you steering.
Terry
Terry, NJ is offline   Reply With Quote
Old 01-02-2017, 09:01 AM   #19
krzewinskibe
Terry
No...ground to frame height at each corner varied 1/2" . Easily attributed to the busted spring and seized/busted shocks I found. Spring appears to be more of issue with rough roads...several leaves cracked at the center bolt. Frame area directly above the spring was cracked too....I cut that area out and TIG welded in some fresh metal.
1929 Tudor
Old 01-02-2017, 09:02 AM   #20
krzewinskibe
that was only an eyeball guesstimate...it's probably much less than 1/16....
1929 Tudor
