Old 03-11-2017, 06:19 PM   #1
Doug in NJ
Doug in NJ's Avatar
Default Oversize rear wheel grease seals?
Hello,
I have heard that in the recent past, some vendors were selling oversize rear wheel grease seals. I just bought a pair, and they measure 3.1930" in diameter.
I measured the inside of the hub where the seal goes, and it was only 3.1875"
in diameter. So the seals are about 0.0055" oversize. Is this actually the way it ought to be? If so, how much oversize were the bad seals?
Thanks,
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 03-11-2017, 09:58 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Oversize rear wheel grease seals?
I wiped out a new seal the first time I tried to install one of the wrong oversize seals.
Old 03-11-2017, 10:24 PM   #3
31a
I ordered seals from Mikes would not fit called took credit trashed ordered from snyders fit perfect
31a is offline   Reply With Quote
Old 03-11-2017, 10:26 PM   #4
Beauford
Yup...was just in garage with Mikes seals...I ruined one trying to get in..
Beauford is offline   Reply With Quote
Old 03-11-2017, 10:29 PM   #5
BruceKC
BruceKC's Avatar
I just installed them and my measurments were the same. Place them in the freezer for 30 minutes and pack the inside with grease so the spring will not come out.
BruceKC is offline   Reply With Quote
Old 03-11-2017, 11:48 PM   #6
Beauford
I just ordered some Bratton's and they say same thing...I hope I dont mangle them!
Old 03-12-2017, 06:53 AM   #7
George Miller
George Miller's Avatar
They were like that 20 years ago. Why can't they get it right. Some say we are lucky to be able to get this junk.
George Miller is offline   Reply With Quote
Old 03-12-2017, 11:25 AM   #8
Bob C
I just looked in my seal interchange and it shows A-1175 with 3.194 OD.
Bob
Old 03-12-2017, 01:48 PM   #9
ursus
I agree! I recall hearing than some have resorted to sanding away the excess in order to make them fit.
Old 03-16-2017, 02:07 PM   #10
KR500
KR500's Avatar
If I was given a seal 3.194 diameter, I would belt sand it down to fit. If worried it might channel grease past outside diameter, coat outside diameter with a small amount of silicone. .005 press fit is ridiculous when the snap ring locks the seal in place.
KR500 is offline   Reply With Quote
Old 03-16-2017, 02:34 PM   #11
Tom Endy
Tom Endy's Avatar
This problem has been around for years. I believe the seals offered are for a different application. A&L recognized the problem a few years ago and came up with ones that fit. I don't know what they did, they may have turned them down. Since then some of the other suppliers may now offer them as well.
Tom Endy
Old 03-17-2017, 08:26 PM   #12
Doug in NJ
Doug in NJ's Avatar
My calculations show that if you can cool the seal and heat the hub to get a temperature difference of 130 degrees Celsius ( 234 degrees F), the seal will slide right in. But doing that would be rather difficult...
If will be a few weeks before I have a chance to try.
Doug
Old 03-18-2017, 03:14 AM   #13
Beauford
Got my Brattons seals the other day and bought their seal driver as a precaution. Put them in the freezer for a hour and they went in with the seal driver.
