Old 10-16-2016, 08:08 PM   #1
henry's 31
Default Are all 30/31 headlight bars the same?
Hi Dear Members:
Can anyone confirm if all the 30/31 headlight bar were the same?
Thanks for your help!
Henry' s 31
henry's 31 is offline   Reply With Quote
Old 10-16-2016, 08:40 PM   #2
Ian in Mississauga
Default Re: Are all 30/31 headlight bars the same?
NO they are not, but I'm in Canada so maybe my info only applies to Canadian Model As. There is a bar that has a stamped steel center section. I have two friends who traded bars so they would both be correct.The stamped one was for the 31 slant windshield.
Ian in Mississauga is offline   Reply With Quote
Old 10-16-2016, 08:44 PM   #3
flatford39
Kinda like what Ian just said. There is a stamped steel one out there but the thing is they all fit every 30 31 model whether they be the stamped steel or the solid bar style.
flatford39 is offline   Reply With Quote
Old 10-16-2016, 08:52 PM   #4
CarlG
CarlG's Avatar
A 28-29 headlight bar will fit a 30-31, but won't look right.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-16-2016, 10:36 PM   #5
700rpm
700rpm's Avatar
The stamped bars are also prone to breakage. A good, unrepaired original is hard to find.
Ray Horton, Portland, OR
Old 10-16-2016, 11:37 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
Stamped bar used from May 1930 to August 1930
Forged end bar used from the introduction of the 1930 bodies through April 1930
and from September 1930 through the end of production.
Old 10-17-2016, 07:40 AM   #7
jimalabam
jimalabam's Avatar
Mike is correct, follow his direction...
jimalabam is offline   Reply With Quote
Old 10-17-2016, 08:04 AM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Carl,
Is that like a face lift, GONE BAD?
Saw a '30 Coupe, with '29 Splash Shields & Fenders---"Did they fit OK"?----"Don't know, it was like that when I stole it"
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 10-17-2016, 09:29 AM   #9
henry's 31
Thank you all for your help and information. As always you are very helpful.
Henry' s 31
Old 10-17-2016, 11:56 AM   #10
coupe1942
coupe1942's Avatar
My light bar on my '30 ccpu has two holes centered from the mid point of the radiator which go through the bar itself. The two holes face forward and not downward. I am assuming that they may be there for license plate holders to be attached, but that is just an assumption on my part. They seem too far for he average license plate mounting of today. This is the bar that came on the pickup when I purchased it and I have no idea if it is original or not to the truck. Am I correct as to the purpose of those two holes or is this a light bar adapted on it from some other Model A?
I never had a front license plate on any of the previous Model A's I have owned and never remember noticing them or even checking for holes like these on my current pickup.
I saw a fellow at Chickasha carrying around a light bar with the buckets attached, but I forgot to look it over to see if it had the same holes in it.
coupe1942 is offline   Reply With Quote
Old 10-17-2016, 12:21 PM   #11
CarlG
CarlG's Avatar
Originally Posted by BILL WILLIAMSON View Post
Carl,
Bill W.
You should be able to see the difference here: The first picture is with the '29 light bar, the second one is with the '31 light bar. The earlier bar puts the head lights a couple inches higher on the truck.
Alaskan A's
Old 10-17-2016, 01:23 PM   #12
Tom Wesenberg
Tom Wesenberg's Avatar
If you have a round light bar with holes to mount the license plates, then some owner drilled them.
In the old days license plates with long numbers were often long plates with wider spaced mounting holes. That's one reason I'd like to find a 3 or 4 digit plate, rather than a 5 or 6 digit.
Old 10-17-2016, 01:34 PM   #13
coupe1942
coupe1942's Avatar
Yes, in holding up a new stock license plate, the mounting holes are a good 1-1 1/2" further apart than the holes on the plate are.
I have a new custom license plate coming and I'll end up having to figure a way to mount it other than using these two pre-drilled holes. I want to secure it well enough that some 5 finger discount person won't just pull it off with a slight tug. Time to break out the 50 million megawatt, but only 1 amp, Miller welder, huh? The lights may soon dim in my neighborhood. It's alive! It's alive! :-)
Thanks for the info.
Old 10-17-2016, 01:41 PM   #14
CarlG
CarlG's Avatar
Originally Posted by Tom Wesenberg View Post
If you have a round light bar with holes to mount the license plates, then some owner drilled them...
x2.
Alaskan A's
Old 10-17-2016, 01:57 PM   #15
Doug in NJ
Doug in NJ's Avatar
A few years ago I bought a nice bar at Hershey with holes exactly as you describe, and a few days later I realized that they were not original.
I filled them in (with metal, not bondo) and painted the bar, and it has been on my car ever since.
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 10-17-2016, 05:34 PM   #16
Bruce Lancaster
Holes would have been impractical for production, as license size varied a good deal between states. That's why stamped one had slots and the bar had the movable clamps.
