05-20-2010, 03:41 PM | #1 |
VIN Location on a '35-'37 "Big" Truck
Is the VIN in the same basic location, on the top of left frame rail, as on passenger cars and pickups? Is it located anywhere else?
I need to find it and get it right to apply for a duplicate title. Thanks. Clay |
05-20-2010, 05:34 PM | #2 |
Re: VIN Location on a '35-'37 "Big" Truck
As I understand it was stamped into the top of the bell housing. You'd have to remove the transmission cover to see it. Stu
05-20-2010, 06:01 PM | #3 |
I would near the steering box top frame rail.
05-21-2010, 05:39 AM | #4 |
Legability is best on the trans flange and the best to get a tracing from as what NY wants. I have one with no numbers but most do, understand factory replacements were the only ones blank. Some big trucks have a data plate and include the VIN riveted inside the glove box door, but the ones I had were postwar, maybe not done early.
05-21-2010, 08:14 AM | #5 |
I just found my '36 BB number on the top of the frame near the steering box. It took a lot of scrubbing with a wire brush to find it. After you find it, rub with a white crayon to make it more legible. It will start out " BB18-xxxxxxx " with a star at each end.
05-21-2010, 09:34 AM | #6 |
Here is some info from the HAMB on how to "raise" the chassis numbers if they are to faint to read. http://www.jalopyjournal.com/forum/s...highlight=acid |
