04-02-2019, 01:51 AM | #121 |
Re: How To Lower The Model A The Old Fashion Way
Yes, McMaster Carr has the correct ones I.D. is 11/16
04-02-2019, 07:25 PM | #122 | |
Do you have a plan for steering? Shocks? Rear brakes? Master cylinder, etc., etc.. Lots involved in this changeover. |
04-02-2019, 11:37 PM | #123 |
My car already has the '46-'48 juice brakes and spindles on the "A" axle. I will just be changing out the A for the '32-'36. The steering has already been adapted. I am using Armstrong shocks.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
04-03-2019, 02:49 AM | #124 |
OK, makes sense now. Also I meant to say: "The 46 spindles will bolt onto the '32-'36 axle using the 46 kingpins and the bearing placed on the bottom as it was originally for '46."
What do you have now for kingpins - they should work the same on the '32-36 axle(?) |
04-03-2019, 08:21 AM | #125 |
Are you still running mechanical brakes? Do you notice a difference after lowering?
Isaiah B. 1928 all metal Tudor |
04-03-2019, 11:32 AM | #126 |
I went with hydraulic brakes because I upgraded my power train to. 283 V8, T5, Ford 9" rear. I can cruise 65 mph at 1,800 rpm and I'm getting 18 to 19 mpg. |
03-10-2020, 08:57 AM | #127 |
10-05-2022, 08:52 PM | #128 |
10-05-2022, 09:05 PM | #129 | |
