08-22-2014, 01:54 PM | #1 |
37 Torque Tube Assembly
When I took my '37 torque tube apart, there was a lot of pieces of the seal and other parts, so nothing to go by to reassemble. Two basic, but important questions. Which way does the front seal face and are you supposed to pack the bearing? This is an early '37 with no center bearing. Just when you think you know what your doing, you get proven wrong.
Thanks, Chris |
08-22-2014, 03:32 PM | #2 |
Re: 37 Torque Tube Assembly
The seal is there to keep the grease in the bearing, speedometer gear, and U-joint housing and keep dirt and moisture out. It's a good idea to pack the front bearing, get grease over the speedometer gear as well as the splines on the drive shaft and the inner u-joint cover & outer U-joint cover halfs and the flared end of the torque tube inside and out before assembly. You would install the seal the same as the wheel seals are installed to keep the grease in the wheel bearings and dirt out.
08-22-2014, 03:33 PM | #3 |
The seal goes in first with the sealing lip towards the transmission. That way any pressure build up from the rear end can push past the seal and vent. Pack the roller bearing with grease.
08-22-2014, 03:35 PM | #4 |
If you have not figured it out already, the sleave bearing has to come out to replace the seal.
08-22-2014, 03:49 PM | #5 |
Thanks to all for the information. Now I can start putting things back together.
10-03-2014, 08:14 PM | #6 |
Walt |
10-03-2014, 10:37 PM | #7 |
That sleeve or race for the bearing has a dimple in it that locates it in a depression and keeps it from spinning. Look for both of these things and it will become apparent how it goes.
10-03-2014, 11:12 PM | #8 | |
I made a ring that compresses that bearing. Then you can insert the bearing while aligning the dimple with the depression, and tap the bearing in place with someting softer than the bearing. The ring just falls out of the way as the bearing goes in.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 10-03-2014 at 11:18 PM. |
10-04-2014, 03:49 AM | #9 |
I have come across 37 torque tubes where it doen't have the 'dimple' type bearing race... has a thicker one piece sleeve that is real difficult to remove.
10-04-2014, 05:13 AM | #10 |
Yes the ' open' end goes towards the trans.. Now this can be the 'soft' side depending on what type of seal you have .. I've just done mine and it was a PITA to get started . I used the apropreate sized socket on an extension .. Once it started to go I thought yup drove it in.. However I did not feel it go home and hit it a few more times than I should.. It's pushed the metal edge back towards the seal, it not real special but I think it will be ok. So go a bit at a time to make sure , my mistake may help you get yours just right..
