04-22-2015, 01:59 PM | #1 |
Tri Power carbs and Linkage (Restored Carbs)
City:
Shelby Twp.
State:
Michigan
Price:
$600 +ship
Lowered Price ! SOLD
This tri power set up has 3 professionally restored Ford/Holley 2110 3 bolt carbs that came from 1956 Fords with a 272. I chose these carbs because they have the 1 1/16" venturi plus the larger throttle bores. A little higher air flow than the previous 3 bolt carbs. I made the linkage to be adjustable for all tri power manifolds out there, to compensate for different carb spacing. The linkage is progressive and fully adjustable if you do not want the end carbs to fully open for stock or small displacement engines. The center carb has an automatic choke for convienience, with an electric heated thermostat cap and a one wire hook up. Jetting and power valves are all stock original calibration. The end carbs have the idle mixture screws turned in, so you idle off of the center carb. The end carbs still have the idle progression holes working to help eliminate a hesitation when opening them up. Also have eliminated the choke valves and shafts on the end carbs and plugged the shaft holes. Just need to bolt them on, adjust the linkage length for you're manifold and add air cleaners/fuel lines. All work is guaranteed. Carbs will be shipped bolted to a board with the linkage installed so you can see how to install. Thank you, Sal Cicala (586) 612-1650 [email protected] Last edited by scicala; 11-04-2015 at 06:15 PM. Reason: Lowered price. |
04-27-2015, 02:30 PM | #2 |
Re: Tri Power carbs and Linkage (Restored Carbs)
Again.
05-04-2015, 03:52 PM | #3 |
Again.
05-20-2015, 02:46 PM | #4 |
Again.
05-24-2015, 07:06 PM | #5 |
Again.
06-18-2015, 11:00 AM | #6 |
09-06-2015, 11:43 AM | #7 |
Again.
10-28-2015, 02:09 PM | #8 |
Again with lowered price !
