10-30-2014, 03:27 PM | #1 |
Judging condition of axle taper's
How would I go about valuating the taper on the end of the rear axles? Don't want to put everything together and then have to use shims on the axle tapers. Any way to measure them? Thanks, Tom
10-30-2014, 03:37 PM | #2 |
Re: Judging condition of axle taper's
I do not know the size. But if they have been run loose, the key slots will be wore and the keys will be loose in the key slot.
10-30-2014, 03:39 PM | #3 |
I wanted to know this too. I've read where it's supposed to be 1 1/2 degrees per foot if I remember correctly.
I'm curious to know which is harder the axle or the Hub. The Axles file down easily as if they are not hardened at all. I had to do both of my 5/8 threads down to 9/16 as they were damaged/stripped from previous owner. Anyone have a Blueprint??? I'm a Quality Control Inspector and have a CMM at work that I can use to measure the Taper with down to millionths of an inch. The problem is my spare axles have some lite surface rust. The CMM will be influenced by this to some degree. |
10-30-2014, 04:06 PM | #4 |
On your axles, try some evaporust to get off rust without any acids that might affect things.
Fort archival drawings of parts are filed by part number...that might be a source of information. One interesting factoid I ran into in a circa 1946 Ford ad was that axles had three different heat treat zones, I would assume gear, shaft, and taper. I haven't yet found any Ford patents on the actual axle shaft, but I bet there are some on these things. Making gear integral for strength and cost savings was a primary claim on the patents for the rear end assembly. |
10-30-2014, 04:22 PM | #5 | |
After the first "scrub" you will easily be able to see any low spots. If the taper is not too badly scored, you should be able to get a 100% surface after some lapping. The keyway should not be loose at all. As a side note, the taper actually drives the wheel, NOT the key. |
10-31-2014, 08:30 AM | #6 |
10-31-2014, 08:43 AM | #7 |
Lapping is a process which removes 10 thousandths of an inch. Lapping, or even grinding using cloverleaf (more on the scale you need here) MIGHT remove 0.001. With a 6/1 taper this would move the wheel in 0.006.
Like the amount you bend the perimeter of the backing plate as you remove it with your hand and it's stuck on the paint. I would go for a quick grind with 180 Cloverleaf and call it done. Joe K
Shudda kept the horse. |
