10-30-2014, 02:46 PM | #1 |
Brake Floater Kit Question
I have reviewed many of the posts related to the pros and cons of using the Flathead Teds brake floater system. I compiled the cost of rebuilding my backing plates against the cost of his kit. I contacted Ted and he gave be some background information. I tried to change the front backing plate tracks and was not successful using the small tool provided with the tracks. Using his kit appears to be the most cost effective option for me with a limited budget; am I wrong?
10-30-2014, 04:03 PM | #2 | |
Re: Brake Floater Kit Question
Jerry, I realize that everyone has a "budget" and priorities as they are, sometimes funds can be slim but I see a couple fallacies with this entire situation. First off, the little tool that is sent is only a spacer to protect the spring-end of the rivet. The peening of the rivets must be done with proper tools, --or by TIG welding the backside. The new rivets (-if you have damaged yours) are available from Vendors. THAT would be the first effective option! Weld up your old tracks and grind/file them does not cost that much money. 2nd, you MUST (for the safety of YOU, Your Car, ...AND the safety of other motorists driving around you) repair ALL of the brake system for it to work correctly. It is my opinion the F/H Ted system is only necessary to "band-aide" something else that is faulty. That kit is a minimum of $150.00 ....and I am hearing you complain that you are on a limited budget. Fix what you have first before investing in the kit!! |
10-30-2014, 05:24 PM | #3 |
Flathead Ted's kit is designed to be ADDED after the brakes have been rebuilt, NOT instead of fixing everything first.
Paul in CT |
10-30-2014, 05:58 PM | #4 |
Good responses. I have a 30 Town Sedan with restored brakes and cast iron drums that stops great. I have a 28 roaster with restored brakes with steel brake drums that are well adjusted and stops are downright scary sometimes. There can be many other factors, so it isn't a totally fair comparison, but my winter project is putting cast iron drums on the roadster. New drums are expensive, but a very worthwhile investment in safety. My point is the same as the others: many factors can cause your problem. Make sure you have diagnosed it properly first.
10-30-2014, 07:49 PM | #5 |
Its really not necessary to have to replace every part of the brakes to have good brakes. Only the parts that are worn past the point of adjustment taking care of will have to be replaced . If the brakes wear on the modern car you don't replace the whole system, only the needed parts are replaced . Adjustment and proper setup of the service brake shaft , brake rods and shoe adjustment solves a multitude of sins with the model A brakes. On the other hand, a person can spend thousands of dollars replacing every part of the brakes and still be no better off if the brakes are not setup and adjusted properly. |
