02-04-2014, 10:25 PM | #1 |
Strangest place you've found the Ford script
Over the years I've seen the Ford script on all kinds of parts such as rear axle keys, spark plug connectors, etc. Last week I was cleaning up an old shadowbox that my Dad made me back in the early 70's and noticed this front spindle nut with the script. I don't ever recall seeing another one of these before now.
Where's the most unusual place you've found a Ford script stamped? |
02-04-2014, 11:07 PM | #2 |
Re: Strangest place you've found the Ford script
These valve cover gaskets have a script in the lower left corner ---a little hard to see in this picture though
02-04-2014, 11:16 PM | #3 |
I don't know about being the strangest, but this is the smallest place I have seen a script. Driveshaft roller bearing.
Matt 24:36-41 |
02-04-2014, 11:28 PM | #4 |
Every bolt on a friends WWII Ford built Jeep.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
02-04-2014, 11:32 PM | #5 |
emergency brake lever bushings on 29 worm drive AA rearend that seed thing is a piece of maple leaf on concrete for size comparison...
1929 Model AA - Need long splash aprons! |
02-05-2014, 12:56 AM | #6 |
02-05-2014, 01:14 AM | #7 |
02-05-2014, 01:30 AM | #8 |
Here's another one I found recently on the reverse idler shaft from an early 28 transmission I'm assembling. Unfortunately the cluster gear shaft didn't have a matching script, although it wasn't useable anyway.
Definitely not as cool as the cookies above! |
02-05-2014, 07:31 AM | #9 |
Rear hub seal.
02-05-2014, 07:59 AM | #10 |
On someones back?
Photos of tatoos Saddly, I think if you looked hard enough there would be scripts in places you just do not want to see. |
02-05-2014, 08:10 AM | #11 |
I found the ford logo on the inside of the leaves of a rear spring recently. Now why would Henry have thunk to put it there?
02-05-2014, 09:04 AM | #12 |
on a couple of anti freeze cans I have
Hotrods don't have valve covers |
02-05-2014, 09:08 AM | #13 |
I have a brass clad head gasket that has the Ford script. Taken out of a low mileage engine.
02-05-2014, 09:52 AM | #14 |
I thought this was a strange place. I tried to find one on a hottie but there werent any.
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
02-05-2014, 10:10 AM | #15 |
On a set of model b points
02-05-2014, 11:28 AM | #16 |
I found the Ford script on these spring clips, that I found in a Ford garage, many years ago.
MIKE (mikeburch) CLICK ON PHOTOS TO ENLARGE - Twice |
02-05-2014, 05:28 PM | #17 |
Found on headlight bulbs when we restored 1928 fire truck for village of Northport MI
02-05-2014, 05:33 PM | #18 |
I have the tip of a quill pen that has a Ford script. I assume the drafting dept in Dearborn bought hundreds of them to their specs.
02-05-2014, 05:35 PM | #19 |
Hey 1930 Coupe!! That's a good place to look. I'm starting right now.
02-05-2014, 05:58 PM | #20 |
