10-24-2022, 11:52 AM | #1 |
Clutch adjusted out as far as possible but need more
So I have my clutch pedal adjusted out as far as I can and the clutch still engages just off the floorboard. At this point, do I need to adjust the fingers in the clutch outward more?
10-24-2022, 01:20 PM | #2 |
Re: Clutch adjusted out as far as possible but need more
Sure sounds like you need to adjust the pressure plate fingers. I had to do that too and it made a HUGE difference.
10-24-2022, 01:35 PM | #3 |
You need to adjust the fingers on the pressure plate. The adjustment on the rod only adjusts the distance between the throw out bearing and the fingers on the pressure plate. Supposedly a pressure plate coming from a supplier is supposed to be factory adjusted. I have found this to not be the case, and always check the adjustment. The attached article tells you how to do it. It is possible to do it through the removeable plate where you grease the throw-out bearing.
http://www.santaanitaas.org/wp-conte...adjustment.pdf Tom Endy |
10-24-2022, 04:39 PM | #4 |
If you are saying that the adjustment is screwed in as far as it can go and you cannot disengage the clutch until it is close to the floor, then the fingers need adjusting as others have said. By the way, you need one inch of free play at the top of the clutch pedal so that you do not burn out the clutch from slipping.
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 10-24-2022 at 04:46 PM. |
