Old 05-12-2018, 01:18 PM   #1
JDakota
Default zinc in motor oils
Do any of the 15/40 or 20/50 0ils have zinc or should this be added to the oil?
JDakota is offline   Reply With Quote
Old 05-12-2018, 01:38 PM   #2
Brentwood Bob
Default Re: zinc in motor oils
Do a thread search. This question has been answered.
Brentwood Bob is offline   Reply With Quote
Old 05-12-2018, 01:44 PM   #3
1955cj5
1955cj5's Avatar
Here is the result of a google search...
https://www.fordbarn.com/forum/showthread.php?t=189632
Add ZDDP if you are still unsure!
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 05-12-2018, 01:47 PM   #4
WHN
We add one blue bottle of STP at each oil change to get the ZDDP.
Use Walmart 20w-50 oil.
Old 05-12-2018, 02:37 PM   #5
40 Deluxe
There is more than enough zinc in any modern oil for an A. After all, the oil that came with your A when it was new out the factory door, had no zinc in it!
I doubt that non-detergent oil has any zinc in it, and that is all some guys will allow in their A's!
Old 05-12-2018, 03:42 PM   #6
jimvette59
jimvette59's Avatar
The zinc is needed by high compression engines especially the push rods where there are heavy springs etc.etc.. I use Brad Penn 20-50 in my 67 327 300+ hp it has some work done to it but I don't need to go over it here. JMHO
jimvette59 is offline   Reply With Quote
Old 05-12-2018, 03:49 PM   #7
jimvette59
jimvette59's Avatar
JDacota yes they do but you will pay a price for it as I do in my 327 300 + hp. Yes the zinc was lowered in some popular oils but still have enough for some small engines. I use Brad Penn 20 - 50. im my Corvette. JMHO
Old 05-12-2018, 09:15 PM   #8
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
The new dello 400 SDE. 15/40 has 800ppm. Plus other anti wear properties.
Old 05-13-2018, 05:48 AM   #9
Pete F
Pete F's Avatar
I don’t know what Year oil started having zinc add to it but I do know by the fifty’s it had it and I also know the EPA had it removed a few years ago.
Ask any cam grinder they will tell you that cam failures have happened more know than ever.
We may not be running the valve spring pressure that race motors have but we still have metal to metal that can wear over time without the zinc.
So for a couple dollars is it worth trying to prove someone wrong.
Pete F is offline   Reply With Quote
Old 05-13-2018, 08:06 AM   #10
Standing Elk
According to the the analysis I read on this forum Mobil One 15W-50 has nearly 1000 ppm of Zinc.
Standing Elk is offline   Reply With Quote
Old 05-13-2018, 11:38 AM   #11
29er
29er's Avatar
Also check here:
https://www.vintagefordforum.net/for...ll-information
29er is offline   Reply With Quote
Old 05-13-2018, 11:57 AM   #12
Jeff/Illinois
Jeff/Illinois's Avatar
Most of my car friends that have high performance engines use Brad Penn Motor Oil good stuff.
Not needed in a Model A. Use a bottle of ZDDP for about 9 bucks at oil change time with your favorite brand of oil if you want. You can buy it thru the parts vendors.
Old 05-14-2018, 01:32 AM   #13
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by 29er View Post
You have to change the dot net to dot com for the link to work.
Old 05-14-2018, 11:38 AM   #14
Jim Brierley
A's have steel cams, most late model V8's have cast iron cams, a critical difference. Also A's have very little valve spring pressure compared to OHV, high revving engines.
Old 05-14-2018, 08:30 PM   #15
29er
29er's Avatar
Thanks Mike. I tried to edit my post, but it's not buying it. Just Google "ford vintage" and search "zinc". Some useful info there as well as on this site.
Mike
