08-16-2019, 09:30 AM | #1 |
Fan Belt Squeak
My fan belt is not too old but it is starting to squeak a bit. What can I use to dress it? I have some belt dressing in a spray can in the garage but it makes such a mess when I use it. I remember years ago there was something like a crayon that would help. What do you say?
Marty |
08-16-2019, 09:41 AM | #2 |
Re: Fan Belt Squeak
Try bar soap. Works every time.
Dick |
08-16-2019, 10:54 AM | #3 |
Re: Fan Belt Squeak
I recently had the same problem and tried all the common dressings, none worked.
I ended up sanding the belt, nice and quiet now. |
08-16-2019, 01:01 PM | #4 |
Re: Fan Belt Squeak
Try WD40. Just spray a little on belt at top of generator. Very little.
Has always worked for me. No mess. Enjoy. |
08-16-2019, 01:49 PM | #5 |
Re: Fan Belt Squeak
With engine running SLOW, A bar of bath soap held on belt edges..
08-16-2019, 01:53 PM | #6 |
Re: Fan Belt Squeak
The Master Cylinder Enjoying life at the beach in SoCal... Last edited by The Master Cylinder; 08-16-2019 at 03:15 PM. |
08-16-2019, 01:59 PM | #7 |
Re: Fan Belt Squeak
Hallo Marty, the squeaking comes when the V-belt slips. If you apply a lubricant such as soap or WD40, you will not hear it squeak anymore, but the belt is still slipping. The solution is candle wax. Rub the flanks of the V-belt with it and the belt runs noiselessly and without slipping.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
08-16-2019, 02:09 PM | #8 | |
Re: Fan Belt Squeak
Squeaking is not just caused by slipping fan belt. The Model A’s generator isn’t always in perfect alignment with the other two revolving pulley’s. As the belts age, the edges dry out, and the slight mis-alignment causes a squeak. I am never 100 percent right, but I’ve been at this for a long time. Try the WD40, just a very little on generator pulley. Enjoy. |
08-16-2019, 02:28 PM | #9 |
Re: Fan Belt Squeak
If your worried about slippage, use Gasgacinch Gasket Sealer and Belt Dressing https://www.amazon.com/Gasgacinch-44...s%2C199&sr=8-1
The Master Cylinder Enjoying life at the beach in SoCal... |
08-16-2019, 02:49 PM | #10 |
Re: Fan Belt Squeak
Thanks for all the replies. I did spray with WD40 a week ago but I think that is a temporary fix. The squeak came back. Now I have a bunch of things to try.
I can't wait to get started. Marty |
08-16-2019, 02:55 PM | #11 |
Re: Fan Belt Squeak
My experience as well. If you look at the sides of the belt you'll probably see that the belt is glazed. Sanding cuts this glaze and quiets the belt, no dressing required.
08-16-2019, 03:09 PM | #12 |
Re: Fan Belt Squeak
ryanheacox. times 2 :-)
Steve Hanna, Polk City, IA |
08-16-2019, 03:44 PM | #13 |
Re: Fan Belt Squeak
Might try a new BX40 or BX41 belt. It is the cogged type and may help.
08-16-2019, 04:26 PM | #14 |
Re: Fan Belt Squeak
We used to use Door Ease, it comes in a stick and you rub it on the belt edges. https://www.amazon.com/AGS-DEK3-Door.../dp/B000CIFVN6
08-16-2019, 05:27 PM | #15 | |
Re: Fan Belt Squeak
Of course this was back when they had service stations, cash boxes and service attendants. Thanks for the memories. |
08-16-2019, 06:31 PM | #16 |
Re: Fan Belt Squeak
you can cure a squeaking belt by cleaning it and the pulleys. soap and water.
08-16-2019, 07:37 PM | #17 |
Re: Fan Belt Squeak
I have used all of the above, except the sanding. Nothing seemed to work except putting a new belt on. I'll have to try the sanding next time. Oh, I did (do) have the cogged belt.
08-17-2019, 04:07 AM | #18 |
Re: Fan Belt Squeak
ATF you do not need to dress all the belt it will migrate around by itself when running . This works for me and seems to be a long lasting cure .
John in sunny morning Suffolk County England . |
