Old 11-01-2016, 05:36 PM   #1
Dennis Pereira
Dennis Pereira's Avatar
Default !929 Gas Tank
Years ago I welded up bullet holes three or four and spent a lot of hours cleaning rust and scale out of the tank for my 29 standard coupe project and soldering up the leaking steering column support bracket sandblasted and painted and installed . But always worried about the tank sealer I used failing because I didn't take the tank apart to clean . But I had another real nice tank that I had used on another project so today I removed the patched tank and I'm going to use the other one with real nice tern coating as far I can see . Another step backward but piece of mind with no leaks or rust and scale .
Dennis in Kelsey ca
Dennis Pereira is offline   Reply With Quote
