Old 10-14-2013, 04:02 PM   #21
spdway1
spdway1's Avatar
Default Re: !! Sparks !!
Originally Posted by nhusa View Post
Me too. When I reread #1 - #2 did not make sense, but then I remembered that post #1 originally said something about it was sparking and should he do something about it.
The question as originally stated was rediculous so I figured that it was a spoof and answered with the gasoline comment.
If I had said -of course you need to fix it - it still would not make sense because the question was changed to what should I do
Thanks for your help.
spdway1 is offline   Reply With Quote
Old 10-14-2013, 04:39 PM   #22
Tom Wesenberg
Tom Wesenberg's Avatar
Well, if I had the helper in your avitar, sparks would be flying in my car too.
Old 10-14-2013, 04:48 PM   #23
ctvpa
ctvpa's Avatar
Call Craig.
ctvpa is offline   Reply With Quote
Old 10-14-2013, 08:50 PM   #24
spdway1
spdway1's Avatar
I do!! Her diaper was filled after the Backfire !!KAPOW!!
Old 10-22-2013, 07:11 PM   #25
spdway1
spdway1's Avatar
Here is what my starter switch looks like. The is green flaky corrosion under the battery cable stud as you can see and directly under this on the starter. There also seems to be a real close tolerance between the stud and the starter. Thoughts/Suggestions? Thank you.
Old 10-22-2013, 07:25 PM   #26
Tom Wesenberg
The stud doesn't need much clearance, and from what I see your's looks OK. I would remove the stud and strap and clean them. Also make sure the strap springs back all the way and make sure the insulation board is in good shape. It should spring back enough to keep the push rod from having freeplay.
Old 10-22-2013, 07:40 PM   #27
spdway1
spdway1's Avatar
I am confused why the starter rod was sparking, should this rod have negative in it or should it be insulated?
Old 10-22-2013, 08:32 PM   #28
jmeckel
jmeckel's Avatar
If the body of the car to battery is a better return path to the battery under a high current drain scenario like when the starter is running, than the engine to battery path, then if the starter rod touches the body it may spark and try to pull a return path back to the battery that way.
Jon
"If you choose to not decide, you still have made a choice!" RUSH
Don't tell me what you know..... Tell me what you have done.
jmeckel is offline   Reply With Quote
Old 10-22-2013, 09:11 PM   #29
Mike V. Florida
Mike V. Florida's Avatar
Originally Posted by spdway1 View Post
When I attempt to start my AA, the foot pedal rod sparks really bad on the hole where it goes threw the firewall.
What do I need to do to correct this?
Thank you
The part that pushes the copper strip on to the "button" of the started normally has an insulator on it. seems like yours is missing.
