Old 11-14-2013, 03:01 PM   #1
wildwilly
wildwilly's Avatar
Unhappy Gas rust
Sad to say, getting a lot of fine rust showing up in my fuel filter now. Getting to the point now where is slowing the flow of fuel and starving the carb while driving . Hope someone knows the best way to seal tank with out removing a the tank ???
wildwilly is offline   Reply With Quote
Old 11-14-2013, 03:05 PM   #2
bart78
bart78's Avatar
Default Re: Gas rust
I have never seen it done. I would take it out. And take it to a radiator shop and have them vat it. And then seal it.
bart78 is offline   Reply With Quote
Old 11-14-2013, 03:28 PM   #3
ford3
with out removing the tank the only other option is to add another temp fuel filter setup, use a clear filter so you can see what is being picked up, they are cheap and easy to replace
ford3 is offline   Reply With Quote
Old 11-14-2013, 03:35 PM   #4
Ross/Kzoo
Ross/Kzoo's Avatar
And I'm not too sure about sealing it. Modern fuels are playing havoc on sealers from what I understand.
Ross/Kzoo is offline   Reply With Quote
Old 11-14-2013, 03:36 PM   #5
txturbo
txturbo's Avatar
I would put some neodymium magnets in the glass sediment bowl to catch it. I buy the 3/8" round by 3/16" thick ones and use them for all kinds of stuff. One magnet will hang a 5lb sledge hammer on the side of my tool box.
txturbo is offline   Reply With Quote
Old 11-14-2013, 03:42 PM   #6
wildwilly
wildwilly's Avatar
Ok, sounds like I may need to search for the best tank sealant. I have just thought maybe the uses of one of them full car stands that one can rotate a car on, or even some type of bladder bag to fill with air to spread sealant thru out the tank ?? Just Ideas.
Old 11-14-2013, 05:37 PM   #7
DougVieyra
DougVieyra's Avatar
Forget the sealant - at least for now. Your first order of business is to get rid of the rust in your gas tank. The Ford Forum has at least two threads dealing with this issue. Use your 'search' tab in the black bar at the top of this page.
I have been wrestling with this issue for about a year now (I too did not want to take my gas tank out of my already (although 35 years) restored car. It ain't gonna be easy to solve your problem. But the two Ford Forum threads I reviewed did point me in the right direction with excellent suggestions. There are several ways to go about it - you pick out the one that best fits you temperament and inclination.
DougVieyra is offline   Reply With Quote
Old 11-14-2013, 05:57 PM   #8
newshirt
newshirt's Avatar
Tried this?
http://www.fordgarage.com/pages/kellyshutoff.htm
Ray White
newshirt is offline   Reply With Quote
Old 11-14-2013, 06:18 PM   #9
Aok
Aok's Avatar
Originally Posted by newshirt View Post
The method in the link works well for me and a lot easier then removing the tank.
Aok is offline   Reply With Quote
Old 11-14-2013, 06:29 PM   #10
Cockshutt Kid
Before going too far, are you sure the rust is coming from your gas tank. I have been having some issues with a very fine "rust" in several fuel tanks, some of them plastic. Also the fuel delivery company has come and installed filters on all of the farm tanks without being asked. It appears that the ethanol fuel is loosening up dirt and rust in the holding tanks and trucks and it is moving around and ends up...{guess where?} May or may not be relevant, but you might want to think about it before you tear a car apart.
Cockshutt Kid is offline   Reply With Quote
Old 11-14-2013, 06:45 PM   #11
Ed Northrop
Ed Northrop's Avatar
Be careful about boiling tank out at radiator shop as it will remove your paint.
Ed Northrop is offline   Reply With Quote
Old 11-14-2013, 07:19 PM   #12
smurph
smurph's Avatar
Go to a hobby store and buy some small, circular magnets. They are surprisingly powerful and not expensive. Place them in a ring around the fuel valve under the dash. Helps to keep rust from getting in the system in the first place. You will want to do this after you've gotten the major stuff out.
Smurph
smurph is offline   Reply With Quote
Old 11-14-2013, 07:30 PM   #13
eagle
eagle's Avatar
Walmart sells the neo magnets in their craft section. Just bought some yesterday. They come in a (4) pack for $2.94.
eagle is offline   Reply With Quote
Old 11-14-2013, 07:47 PM   #14
txturbo
txturbo's Avatar
also....a lot of radiator shops wont do gas tanks anymore. Contaminates the tank.
Old 11-14-2013, 08:40 PM   #15
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Vermin ran fine when I got him 2 1/2 years ago. Running a stock cast iron sediment bowl & the regular screen in the carb. Dropped the carb bowl & it had an accumulation of rust colored stuff that was fine, like talcum powder, but didn't plug up anything in the carb.
I WON'T use MICRO-FILTERS, as I'm quite sure the fine powder WOULD plug them up! (OH! & a magnet WILL NOT pick up the powder, they WILL pick up rust FLAKES, though!) I'll flush the tank as best I can, & use the little stainless "pencil" filter in the top of my fuel valve, & HOPE FOR THE BEST!!! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 11-14-2013, 09:20 PM   #16
bart78
bart78's Avatar
I think if it were my car. And I planned to drive it for a while. I would go ahead and fix it right. And not worry about it anymore.
Old 11-14-2013, 11:26 PM   #17
Mike V. Florida
Mike V. Florida's Avatar
Smurph
Cow Magnets
Old 11-15-2013, 10:14 AM   #18
Kurt in NJ
Kurt in NJ's Avatar
I cleaned my tank by taking a 2500 mile trip, originally I had a standpipe on the fuel valve, removed it and poured and filtered a few gal through the tank, then set out on the trip cleaning the bowl at every fillip, after about 1500 miles no more debris in the filter , it stayed clean for many years, now 25 years later it needs cleaned once a year.
Old 11-15-2013, 11:58 AM   #19
wildwilly
wildwilly's Avatar
thank you all on your great response to this matter. I do drive this car on weekends around the area. My fuel system is half azz right now, because that's the way we found her. I have an glass inline filter under the dash, in it the fine brown powder stuff building up. Don't see where there are any larger flakes that could clog this carburetor up. The Carb is another story, NOT the norm, it is a Zenith, but all my research on it shows to come from an old Ferggi Mass farm tractor. It does look like a real fine brown powder as I have read in one replay. My next step I shall try, I guess, Is to test that brown powder to see if metallic. Also wonder if I can do a tank flush, an run with a filter for now ?? Going to buy the right fuel set up with tax return.
Old 11-15-2013, 12:06 PM   #20
wildwilly
wildwilly's Avatar
Thank you, Will look up old threads.
