04-29-2024, 05:15 AM | #1 |
Float A Motor
Hello all… Can anyone tell me why someone would install a rear Float A Motor
Kit and not a front kit as well? In my pea brain it would only make sense to do both?? I have to replace my Yolk assembly and was wondering if I should install the front Float A motor kit being a rear had been installed at some point. Any input would be appreciated. Thanks |
04-29-2024, 05:22 AM | #2 |
Re: Float A Motor
Sorry forgot to mention it’s a ‘30 sport coupe
04-29-2024, 06:14 AM | #3 |
Re: Float A Motor
My 1930 coupe is setup that way and i have no miseries. Pretty smooth also. I ,M HAPPY
04-29-2024, 06:39 AM | #4 |
Re: Float A Motor
I have the same setup as ray, and i like it.
04-29-2024, 07:12 AM | #5 |
Re: Float A Motor
So you are saying stock mounts in front and float A motor in rear? That’s what this coupe is set up with and it drives great. Guess I’ll leave well enough alone..
04-29-2024, 07:24 AM | #6 |
Re: Float A Motor
04-29-2024, 11:33 AM | #7 |
Re: Float A Motor
Same experience as Nkaminar on both my A's.
04-29-2024, 12:31 PM | #8 |
Re: Float A Motor
I have the stock yoke in front and FAM in the rear.
04-29-2024, 12:57 PM | #9 |
Re: Float A Motor
I will keep it that way as well. Thank you all!
