01-06-2022, 09:33 PM | #1 |
4 Square Holes in Model A Coupe Inner Door Panel - what for?
A gentleman just asked me what the 4 square holes and the corresponding center hole are for in this Model A Coupe door inner panel.
I don't know, so I came to you all. Is it for adjustment? |
01-06-2022, 10:09 PM | #2 |
Re: 4 Square Holes in Model A Coupe Inner Door Panel - what for?
What year?
01-06-2022, 10:28 PM | #3 |
1930 Coupe
01-07-2022, 09:24 AM | #4 |
Anyone?
01-07-2022, 09:59 AM | #5 |
Isn’t it to receive the window regulator?
01-07-2022, 10:06 AM | #6 |
01-07-2022, 11:30 AM | #7 |
It holds the window track assembly that brings the glass up and down.
Bob from Northport Northport, Michigan |
01-07-2022, 11:57 AM | #8 |
01-07-2022, 12:30 PM | #9 |
The upper one is for the crank handle that has an arm on it. It attaches to a long wide bar that the glass sits in It in turn attaches to the crank arm. I'll send photos this afternoon.
I have a coupe in my shop with the doors completely opened up
01-07-2022, 01:11 PM | #10 |
Thanks.
All my doors (currently 4 of them in the shop) only had the 3-hole window crank/regulator assembly mounted in the holes diagonal from the circled area. My build has been so slow I'd never thought about the other square holes until I was asked. |
01-07-2022, 06:16 PM | #11 |
I misspoke. The four holes are NOT used at all on a coupe. They are the same as a four door car. The four holes are where to door opening handle mount. Coupes are different.
This photo of the drivers on a sport coupe might help. Ford may have used the same panels in different car doors
Bob from Northport Northport, Michigan Last edited by Bob from Northport; 01-24-2022 at 09:39 PM. |
01-07-2022, 06:36 PM | #12 |
The mystery continues! Thanks.
01-08-2022, 09:51 AM | #13 |
Mounting holes for optional power window regulator.
01-08-2022, 09:58 AM | #14 |
Ford put that feature there so we can easily pick out coupe doors at swap meets, auctions, dusty barns, and in past times junkyard door piles.
