Old 10-28-2023, 02:10 PM   #1
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Default 33 Tudor dash removal
Do I have to remove these two screws on each side at the top? Looks like the only way to get a screwdriver driver on them is with the windshield chrome removed!! How does the w/s chrome come off? Thanks.
Tim Carlig
dean333 is offline   Reply With Quote
Old 10-28-2023, 03:04 PM   #2
34fordy
34fordy's Avatar
Default Re: 33 Tudor dash removal
Raise the windshield?
34fordy is offline   Reply With Quote
Old 10-28-2023, 03:42 PM   #3
dean333
dean333's Avatar
Oh yeah!! Duh!! Sometimes you can’t see the forest for the trees!
Tim Carlig
Old 10-28-2023, 03:56 PM   #4
rich b
rich b's Avatar
Should be six screws total across the top.
rich b is offline   Reply With Quote
Old 10-28-2023, 04:55 PM   #5
dean333
dean333's Avatar
Yep, easy peasy with the w/s cranked open.
Tim Carlig
Old 10-28-2023, 06:04 PM   #6
highbeams
highbeams's Avatar
been there; done that. Those six miniscrews are similar to the Snow White and the Seven Dwarfs; there was a grumpy one that didn't want to come along.
Actually three grumpies; Vice-Grip a head . . . twist it off.
Pull the dash, Vice-Grip the screw shank, turn, and screw it out.
Henry did NOT want them to come out! Besides, he probably thought, who would be fool enough to pull a dash!
highbeams is offline   Reply With Quote
Old 10-28-2023, 06:30 PM   #7
34fordy
34fordy's Avatar
A little fresh air always helps clear the mind dean. Seems like I remember pondering this same conundrum back in 2014. LOL. The same "DUH" moment.
Old 10-29-2023, 12:51 PM   #8
highbeams
highbeams's Avatar
Oh, I don't recall. But if there are screws, unscrew one and see if that gives you a clue. take your time; it'll go better. That's what I did regarding those six little screws at the top; i.e., walk away, come back later. My ws glass was after-market plate glass w/a crack lower passenger side. See it in my Avatar.
Apparently, the original Ford ws glass had been replaced w/this plate glass.
I know that I removed the windshield frame w/the glass in place. Sanders removed the glass from the frame and replaced w/safety glass w/the Ford "Safety Glass" logo using the date that I gave them to match the back window and each door on my three window coupe. The "Safety Glass" logo goes in the bottom corner of your choice. On the assembly line, there was no concern regarding that, I've read, because I wanted it on the correct side; the plate glass had no "Safety Glass" logo, so I wanted to be sure.
Pat Malone
Old 10-29-2023, 04:32 PM   #9
dean333
dean333's Avatar
Highbeams, I had a Duh moment. With the windshield cranked open I had plenty of clearance…10” to get at the screws.
Tim Carlig
Old 10-29-2023, 05:29 PM   #10
DavidG
DavidG's Avatar
Whomever told you that the location of the safety glass logo was a matter of choice was misinformed. The logo wasn't added at the assembly plant, it was added where the glass was manufactured and its placement was specified on the engineering drawings. The logos on surviving original safety glass are consistently located where those drawings specify.
Old 10-30-2023, 11:54 AM   #11
dean333
dean333's Avatar
Since I have the speedo out, what’s the best way to lube it?
Tim Carlig
Old 10-31-2023, 12:59 AM   #12
deuce lover
deuce lover's Avatar
I suggest you have it properly serviced as it should be opened up.Removing the needle can be tricky. Baxter Ford in Lawrence ,KS did mine yrs ago and they were very reasonable.
deuce lover is offline   Reply With Quote
Old 10-31-2023, 01:36 PM   #13
Lawson Cox
Lawson Cox's Avatar
Since I have the speedo out, what’s the best way to lube it?[QUOTE]
We ARE still talking about removing the dash aren't we? (The devil made me do it.)
Old 10-31-2023, 02:48 PM   #14
dean333
dean333's Avatar
Yes Lawson, dash is out. Thought I’d throw in the speedo question. Guess I’ll start a new thread.
Tim Carlig
Old 11-01-2023, 10:24 PM   #15
highbeams
highbeams's Avatar
Yes, it was at Henry's Ford Safety Glass plant is what I meant, or was referring to.
The windshield glass can be installed in the windshield frame with the "Ford Safety Glass" oval logo with its manufactured month and year date, on either side of the glass.
Depending upon the worker installing the glass, the logo will end up on the outside glass, or on the inside glass; on the driver side lower left, or on the passenger side lower right.
Reply/replies welcome. Thank you.
Old 11-02-2023, 08:54 AM   #16
34fordy
34fordy's Avatar
IMHO I cannot imagine that workers would be allowed to put the logo on the inside or outside of their choosing, or even by mistake. The term "Quality Control" was probably not used yet but I am quite sure the quality standards were strictly enforced!
