05-26-2017, 03:36 PM | #141 | |
Re: My 1930 Model A
I figured it had something to do with either the starter or the start switch since I could hand crank it to start no problem. Luckily after working on it today I was just in the switch. One of the insulators had somehow ended up between the two copper contacts. Easy fix and the starter works again. Able to drive around town today with no issues. I'm not a better mechanic than anyone. I'm learning about this car as I go. I enjoy learning new things and have plenty to learn about these cars. Less is definitely more. Someone on here has a saying in their signature that says "If it ain't broke, fix it until it is." That's pretty much how things have been going on my car. But it's been fun. Sent from my iPhone using Tapatalk |
06-11-2017, 04:44 PM | #142 |
Re: My 1930 Model A
So I figured out that one side of the paper insulated inside the switch somehow fell between the two copper contacts. Quick fix and my car is easy to start again. Checked the timing and everything again since it seemed to be getting worse after driving. I was able to drive my A about 30 miles round trip to its first car show. A small all Ford show and she won her first award. It was a terrifying experience at speed on some of the roads here in North Dallas, but I'm loving every mile behind the wheel. Still have some bugs to work out, but she's getting more and more reliable everyday.
06-11-2017, 06:56 PM | #143 |
Re: My 1930 Model A
Hey! I like that Blue, what's it called?
Terry |
06-11-2017, 07:44 PM | #144 |
Re: My 1930 Model A
I wish I knew. I need to do some touch ups. The previous owner painted it in 1975-ish. The gentleman's wife said that he picked it since it was similar to an original color, I believe Hessian Blue. But there's no color on the receipts that I have from when he bought the paint. Sent from my iPhone using Tapatalk |
06-12-2017, 08:17 AM | #145 |
Re: My 1930 Model A
Congrats Lucky. Looks GREAT! Jeff
Let's let pylons, be pylons! |
06-12-2017, 11:17 AM | #146 |
Re: My 1930 Model A
07-07-2017, 04:34 PM | #147 |
Re: My 1930 Model A
Lots of changes going on in the shop. I'm working on installing a set of Ken Davis shocks so my car will actually have shocks on it now.
I've got a new set of tires since the ones that were on were at least 40 years old and hard as a rock. While the tires are off I'm gonna have the wheels media blasted and repaint them black since there's a bunch of chips and I'm not sure how to match the blue that the previous owner used. While I was fixing the head gasket I noticed a crack in one of the ears on the water neck so I ordered a new one and the previous assumptions are correct. I had a 28-29 neck before. Original is on the left, new part on the right. I have a temperature gauge to install but the holder doesn't line up anywhere close. I may have to Fab something up if I can't exchange the one I got. I also got a bunch of other miscellaneous parts and hardware to replace or just install because it wasn't there in the first place. Sent from my iPhone using Tapatalk |
07-07-2017, 06:12 PM | #148 |
Re: My 1930 Model A
It's been fun following this thread especially the first part getting it home. I think it's always exciting with a first time Model A.
07-07-2017, 06:36 PM | #149 | |
Re: My 1930 Model A
Thank you. I'm glad you're enjoying it. I'm sure that many people that are new to Model A's will have similar issues that I'm having. I'm trying to document my progress without being too boring, but didn't want to clutter up the forum with a bunch of threads on each individual project. Sent from my iPhone using Tapatalk |
07-14-2017, 11:37 PM | #150 |
My 1930 Model A
Got my wheels media blasted today. I got a coat of paint on a few of them. It just get too darn hot out in the garage during the day here. Have a few more coats to go. We'll see how much I can do in the morning. She's gonna look a lot different with black wheels instead of the blue.
Purchased a new front leaf spring, center bolt, spring clamps and shackles. All parts came in from Bratton's today, so I'll be borrowing a front spreader from a friend and getting that installed this week. Sent from my iPhone using Tapatalk |
07-22-2017, 10:30 AM | #151 |
Re: My 1930 Model A
I got the new spring installed yesterday, along with new shackles and bushings. And got a coat of color on the last couple of wheels. Hope to get a second coat on all the wheels today.
07-22-2017, 07:32 PM | #152 |
Re: My 1930 Model A
I got one of the tires mounted today. It just got too hot to continue until later this evening. Can't wait to get them all done and see them cleaned up and out in the sun.
07-22-2017, 08:13 PM | #153 |
Re: My 1930 Model A
V
Sent from my SM-J700T using Tapatalk |
07-28-2017, 09:58 PM | #154 |
Re: My 1930 Model A
So I got all the wheels done and the new tires mounted today. I was able to take it for a short test drive to check out the new front suspension as well with the Ken Davis shocks. Amazing difference. Now to install the rear shocks.
Before After Sent from my iPhone using Tapatalk |
07-28-2017, 10:08 PM | #155 |
Re: My 1930 Model A
Looks great with the new tires and black wheels...new lug nuts or did you just clean up the old set?
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
07-28-2017, 10:09 PM | #156 |
Re: My 1930 Model A
08-08-2017, 11:06 AM | #157 |
Re: My 1930 Model A
Looks great. The black wheels were a great choice!!!!
Joe Minneapolis, MN 1929 Std Coupe |
08-08-2017, 11:31 PM | #158 |
Re: My 1930 Model A
Looks better with the black wheels in my opinion. Did you have to cut off the old tires? Nice work!
Zack Minick - 1930 Sport Coupe |
08-08-2017, 11:39 PM | #159 |
Re: My 1930 Model A
08-08-2017, 11:40 PM | #160 | |
Re: My 1930 Model A
Thank you. I had to cut off two of the old tires. The other 3 are still really soft and not cracked. I'm keeping them for emergency spares. Sent from my iPhone using Tapatalk |
