06-04-2015, 07:27 PM | #1 |
Northwest Regional Meet
Jun 23-27th, Walla Walla,WA Are we All Ready!? See you on the way-departing on the 22nd.
www.whidbeymodelaclub.com |
06-04-2015, 07:54 PM | #2 |
Re: Northwest Regional Meet
Will be there, departing the 21st.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
06-04-2015, 10:04 PM | #3 |
Will be there, but I am always there!...At least 40 miles to the north!
06-04-2015, 11:55 PM | #4 |
We will be there, departing Sonoma County California June 20...
A's Always Dave |
06-05-2015, 07:27 AM | #5 |
I sure wish I could go! Unfortunately (fortunately) I will be busy studying that week and wrapping things up at home since I'll be starting a new job with SkyWest Airlines on the 29th. The systems in my new ride are going to be a little more complicated to memorize and operate than a Model A.
I'm finally ditching my 40 year old freight airplanes and my midnight schedule for the shiny floozy shown above. I had a blast at my current, soon to be former company but the show (my career) must go on. I'm sure I'll really be looking forward to when training is over, and I eventually have enough seniority to spend some time at home and get going on the Model A again. The simplicity of the Model A is a great way for a pilot to unwind in my humble opinion! A lot cheaper than an airplane too, and less like actual work! (what I do for a living anyway).
Aaron in Tacoma (although still a Montana hillbilly at heart ) Last edited by montanafordman; 06-05-2015 at 07:41 AM. |
06-05-2015, 09:54 AM | #6 |
06-05-2015, 01:28 PM | #7 |
Will be leaving on the 23rd as a "trailer queen" option. That is I "hope" we will if I can ever get this huckster to run! Still having electrical problems.
Fred Kroon 1929 Std Coupe 1929 Huckster |
06-05-2015, 01:53 PM | #8 |
montanafordman,
Cargo jets are cool... Esp. this baby! 1.3 million lbs. max take off weight!
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
06-05-2015, 03:48 PM | #9 | |
Aaron in Tacoma (although still a Montana hillbilly at heart ) |
06-05-2015, 05:21 PM | #10 |
Actually saw "The" AN-225 land at CLE... making a delivery to NASA GRC a while back when I worked there... The photo does not give the true scale of the beast..
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio Last edited by mshmodela; 06-05-2015 at 06:29 PM. |
06-05-2015, 05:39 PM | #11 |
I've seen it here in Anchorage (on the tarmac) several times. That set of 16 landing gear wheels is something else. That sucker is HUGE!
I read somewhere that they have a couple more partially finished, but can't come up with the funds to complete them.
06-05-2015, 06:27 PM | #12 |
Bring it we will fix it there.
06-05-2015, 07:47 PM | #13 |
When I tried to take it to coffee this A.M., I started it, within a second or two it quit. No amp meter activity. Tried to start it-would not start. I moved the spark lever down, the amp meter started to show the way it should. Moved the spark lever up, amp meter still OK. Started it again, ran for about a second or two and same thing. Left it set-had to get to coffee.
Went to the shop to work on it after coffee today. It acted as if nothing was wrong with it! Moved the spark lever all over the place-no problem-ran like it should. The interesting thing is that I had the same problem with another distributor I had in it which I replace with current distributor. I put a screw driver under distributor to pry it up a bit-no problem. Tried to see if the distributor would turn in the head-no problem. Moved the wire from the coil around-no problem. Moved the wire going into the distributor-no problem. Moved other wires around in the engine compartment-no problem. Just do not know what problem I have!!! So Gary, it may make it on the trailer so I can haul it to the meet and if it still has problems, you all may have a chance to fix it! Thanks for the offer.
06-05-2015, 08:09 PM | #14 |
Fred, have you tried a clip lead between the distributor and a good ground, just in case the hole in the head might not be giving it a good ground?
An original popout cable also offers two more grounding points, the cable head nut mount, and the instrument panel mount. |
06-05-2015, 08:18 PM | #15 | |
Pluck |
06-05-2015, 08:40 PM | #16 | |
Thanks Tom. I will give that a try. But like I mentioned, I want down after coffee today and everything worked the way it should. But I will mess with it some more and see if something turns up (on or off).
06-05-2015, 08:44 PM | #17 | |
Tom, another question about this situation. Could a coil act up like this in the early morning? Maybe caused by the cooler weather or something? Just another thought. BTW sorry about the hijack of this thread.
06-05-2015, 09:19 PM | #18 |
coil is usually when hot.You say you move the spark lever, sounds like a short in the distributor wire. Check that over real good.
06-05-2015, 10:15 PM | #19 |
I agree with Gary.
I'd look for the lower plate wire grounding out, or maybe it's broken. |
06-06-2015, 11:07 AM | #20 | |
Take a real good look at the switch. Good Luck. I've always admired the pics of your Huckster, hope you get it fixed, fast! |
