Old 03-19-2024, 08:17 AM   #1
Seth Swoboda
Seth Swoboda's Avatar
Default Lincoln OD Transmission
Can anyone give me some information about this Lincoln OD Transmission? I believe it's 46-48?? Any useful applications?
Seth Swoboda is online now   Reply With Quote
Old 03-19-2024, 08:31 AM   #2
Will Kimble
Default Re: Lincoln OD Transmission
Useful for supplying 18/26 or 19/25 gearsets!
Will Kimble is offline   Reply With Quote
Old 03-19-2024, 08:34 AM   #3
Tim Ayers
This. More than likely, it will have the 18/26 due to it being a '46/'48. It has all the O/D parts, so an LZ guy would be interested in those pieces.
Old 03-19-2024, 09:11 AM   #4
pistonbroke
I was looking at one for a 40 coup once but it was to much hacking that I wasn't willing to do for the guy. It looked like cutting up the X member and shortening the torque tube and driveshaft would be the big things needed to use it in a ford or mercury. He sold it and we installed a Mitchel OD and never looked back. Tim
Old 03-19-2024, 09:43 AM   #5
Seth Swoboda
Well, this old girl might be scrap yard material.
Old 03-19-2024, 09:45 AM   #6
Tim Ayers
Not before pulling the cluster/gears out you don't!
Old 03-19-2024, 09:55 AM   #7
Seth Swoboda
I'll grab the gears. I'm kinda sad that the OD unit is not useful. I do realize that no one wants a 46-48 Lincoln.
Old 03-19-2024, 09:59 AM   #8
Tim Ayers
Seth,
A LZ guy may want the O/D section, especially since you have the solenoid. Also offer up the shifter plate and the clutch arm. Those are LZ specific parts.
Edit: Looking at it again, yours should be a '48 since it has the "spade" type of clutch arm
Old 03-19-2024, 11:20 AM   #9
petehoovie
petehoovie's Avatar
Old 03-19-2024, 02:30 PM   #10
Automotive Stud
Automotive Stud's Avatar
I have one I thought about putting in my '40 also, I came to the same conclusion, too much work for the payoff. I used the gears out of it in a '49 Merc OD and I saved the tail because the BW overdrive guts look like they would possibly interchange.
Automotive Stud is offline   Reply With Quote
Old 03-19-2024, 02:56 PM   #11
Ken/Alabama
Ken/Alabama's Avatar
Back in the day they would take the overdrive unit off the transmission and install it in the torque tube just ahead of the banjo to give you overdrive. I’ve wondered if there’s any of the old magazines with a how to article on doing this.
Old 03-19-2024, 03:33 PM   #12
rotorwrench
rotorwrench's Avatar
That long actuator rod is a rare bear. Someone will likely want that solenoid. The R10 parts for the closed drive are also valuable to Lincoln owners. Even the governor would have value.
The Lincolns were more of a unit body type car so they had more room for a long unit like that.
Old 03-19-2024, 04:05 PM   #13
jimTN
I have seen one of these in a 46-8 Ford. I think more room to fabricate than the 40 and under frames.
Old 03-19-2024, 07:16 PM   #14
pistonbroke
PM me if you decide to part it out . I would buy the internals of the OD. I don't know how far you are from me but from Hannibal MO. to southern IL. would be doable for me. Tim
Old 03-19-2024, 07:31 PM   #15
42merc
42merc's Avatar
I installed one in a '40 several years ago.
13" out of the torque tube & driveshaft, plus a little crossmember surgery made a great combo.
Mine had a 26 tooth gearset.
42merc is offline   Reply With Quote
Old 03-19-2024, 07:59 PM   #16
Old Magnet
That's not the correct clutch release shaft. Should have an arm not the spade end, not that that's any show stopper.
Old Magnet is online now   Reply With Quote
Old 03-20-2024, 02:43 PM   #17
Automotive Stud
I wound up using that setup in my '40. I think it's a Studebaker unit. Fits well even with a reversed eye spring.
Old 03-20-2024, 03:36 PM   #18
Tim Ayers
That's neat. How is it activated?
Old 03-20-2024, 03:57 PM   #19
petehoovie
petehoovie's Avatar
