Old 11-18-2015, 12:13 PM   #1
mrtexas
mrtexas's Avatar
Default Remove running board rubber
What is the easiest way to remove rubber from 41 running boards? Chipping it off is tedious!
mrtexas is offline   Reply With Quote
Old 11-18-2015, 12:22 PM   #2
r_reed
r_reed's Avatar
Default Re: Remove running board rubber
this is only a guess, would heating it up make it softer? heat gun on low?
1949 F-1 Flatrod II (flat paint, flat motor)
Keeping one more flathead alive
It smoked, but gave it up 7/26/2013
East Glenville NY
r_reed is offline   Reply With Quote
Old 11-18-2015, 12:43 PM   #3
Mark's 37
Mark's 37's Avatar
I used a gasket scraper and a small hammer with good results. The rubber came off in mostly large chunks. An air chisel might be overkill but may work on stubborn areas being careful not to mar or gouge the metal surfaces. The corners and edges are a little tougher and take patience. I didn't try heating thinking the stuff is vulcanized to the metal and it might make it more difficult.
http://s1370.photobucket.com/user/ju...6755b.jpg.html
Mark's 37 is offline   Reply With Quote
Old 11-18-2015, 12:47 PM   #4
39topless
The heat idea is good but you need more than a heat gun. Propane torch with a spreader. Then use the gasket scrapper/paint scrapper.
39topless is offline   Reply With Quote
Old 11-18-2015, 12:54 PM   #5
barnfind
Direct application of dry ice may work. There are some utube videos where they used this for undercoat removal.
barnfind is offline   Reply With Quote
Old 11-18-2015, 02:59 PM   #6
37 Coupe
37 Coupe's Avatar
I used one of those razor type scrapers that I got at Lowes in the flooring department. They are actually made to make a quick job of removing old floor tile. Didn't take long.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 11-18-2015, 06:11 PM   #7
mrtexas
mrtexas's Avatar
The Victor torch worked wonders. I just heated the underside and the stuff almost fell off.
Old 11-18-2015, 07:26 PM   #8
39topless
Cool!
Old 11-18-2015, 10:23 PM   #9
wspiker
wspiker's Avatar
Please do yourself a big favor and buy a new set of complete running boards from Bob Drake. They are excellent and worth the price. On occasion, he does have a sale; it is worth it, trust me.
https://www.bobdrake.com/Categories3...6runningboards
wspiker is offline   Reply With Quote
Old 11-18-2015, 11:24 PM   #10
deuce lover
deuce lover's Avatar
Drake doesn't make the '41 pass car boards
Old 11-18-2015, 11:44 PM   #11
fordor41
fordor41's Avatar
don't think anyone makes '41 boards. Be careful, they're scarce as hens teeth!
fordor41 is offline   Reply With Quote
Old 11-19-2015, 08:20 AM   #12
JM 35 Sedan
JM 35 Sedan's Avatar
Not sure if Hunley Acuff (sp?) Is still in business, or if someone has taken that business over from him, but he/they may be able to mold new rubber on cleaned up boards for you..
John
Old 11-19-2015, 04:17 PM   #13
Lyndon
Lyndon's Avatar
Back in the eighties when I did mine, I spent an entire weekend stripping off the old running board rubber with a hammer and wood chisel. There are some good suggestions posted above for quicker, easier removal methods.
Lyndon is offline   Reply With Quote
Old 11-20-2015, 01:53 AM   #14
Viv W
I use an oxy acetylene torch to heat the rubber and then scrape it off (whilst hot) with a paint scraper. It is a quick and efficient way of getting the rubber off. Best to do it outside with an extinguisher close by, and make sure the wind is not blowing the smoke into your neighbours house.
Viv.
Viv W is offline   Reply With Quote
Old 11-20-2015, 10:09 AM   #15
Ken Dubs
The only way to remove quickly is a torch on the backside and a scraper. Comes off so easy you will want to do more for your friends!!!!
Ken Dubs is offline   Reply With Quote
