Old 05-20-2024, 12:24 PM   #1
2speed
Default Condensor fiber washer
What does the fiber washer on the condensor do?
2speed is offline   Reply With Quote
Old 05-20-2024, 01:03 PM   #2
alexiskai
alexiskai's Avatar
Default Re: Condensor fiber washer
Puts a non-conductive layer between the bus bar and the distributor casting, in case they accidentally make contact.
Old 05-20-2024, 10:22 PM   #3
700rpm
700rpm's Avatar
Is a copper screw necessary or will a standard stainless steel machine screw serve?
Ray Horton, Portland, OR
