01-20-2017, 12:47 PM | #1 |
C4 to block bolt size needed
Bought my engine and trans separate from each other and was wondering what is the correct bolt length. If anybody has this info handy I would appreciate it.
Respecting and Resurrecting Ford Model A's. |
01-20-2017, 01:02 PM | #2 |
Re: C4 to block bolt size needed
Bolt length is dependent on which C 4 you have. Some had thicker bell housing mounts. I like to see 3/4 inch of bolt in the block, but check the depth of the holes in your block.
01-20-2017, 10:59 PM | #3 |
The rule of thumb I have heard that the bolt should go in at least the diameter of the bolt
01-21-2017, 01:40 AM | #4 |
Don't forget the separator plate that goes between the trans and the block. http://www.jegs.com/i/ARP/070/154-0901/10002/-1
01-21-2017, 05:04 AM | #5 | |
Rick West Australia 1958 Ford Mainline Utility, 1955 Ford Tudor Sedan Quote:
