Old 06-05-2016, 09:40 AM   #1
brum1
brum1's Avatar
Default Cowl Band removal
Gents,
What is the best way to remove a cowl band on a 30 coupe?
"no one knows more than everyone"
brum1 is offline   Reply With Quote
Old 06-05-2016, 09:49 AM   #2
james hitchcock
james hitchcock's Avatar
Default Re: Cowl Band removal
There are nuts on each end of the band . They're kinda tucked away at cowl bottom corner. Not the easiest nuts to get to. Once off, the band should come loose.
james hitchcock is offline   Reply With Quote
Old 06-05-2016, 12:17 PM   #3
brum1
brum1's Avatar
Thanks James, will pull the panel and take a look
Old 06-05-2016, 12:36 PM   #4
lookin-backtexas
lookin-backtexas's Avatar
There is no need to pull a panel - the nut holding the cowl band is under the hood; it's not in a very accessible location but feel inside the cowl just beside the clutch pedal and you'll find it.
Fred Carlton
Life Member AACA
44 year member MAFCA
Editor of The Restorer magazine, official publication of MAFCA 12 years
Life Member Dallas Model A Ford Club (44 years)
23 year member & founder Lone Star Model A Ford Club
Chairman 35th Model A Ford Texas Tour 1998 (state convention)
Chairman 42nd Model A Ford Texas Tour 2005 (state convention)
Charter Member Ford Model AA Truck Club
If you aren't driving your antique car frequently, you might as well be collecting clocks!!!
lookin-backtexas is offline   Reply With Quote
Old 06-05-2016, 03:37 PM   #5
lucky_stripe_garage
Here's a couple pictures of where the nut is hiding. It's very awkward to get to. This is the one on the drivers side. My phone was up against the floor.
This one is pulled back a little so you can see the triangle that's formed from the firewall, frame and the floor.
lucky_stripe_garage is offline   Reply With Quote
Old 06-05-2016, 06:43 PM   #6
brum1
brum1's Avatar
Thanks guys, got it
Old 06-05-2016, 06:44 PM   #7
james hitchcock
Thank you to the other members for letting you know that there was no reason to pull your inner panel. I've been gone from the computer. I hope you got to read their posts and see the pic's before you started pulling anything loose.
Old 06-05-2016, 07:13 PM   #8
Roadster62
Roadster62's Avatar
Few shots of Kroil and let it sit for a while, 1/4 inch drive sockets may make access a bit easier. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 06-05-2016, 11:59 PM   #9
mot
Registered User
mot's Avatar
be aware that some early 30s had some bolts holding the side of the band to the firewall ,in addition to the bottom ones
mot is offline   Reply With Quote
