Old 05-30-2013, 06:23 AM   #1
Msaby
Msaby's Avatar
Default Oil change
I am planning on draining the oil on my car this weekend.
* Do I just remove the drain plug and empty the pan?
* Is there a screen or filter of some sort?
* What oil is recommended?
* How may quarts of oil are needed?
Sorry for the basic questions, I am still learning the vehicle.
Thanks
Mike
Msaby is offline   Reply With Quote
Old 05-30-2013, 07:02 AM   #2
al's28/33
al's28/33's Avatar
Default Re: Oil change
5 quarts non-detergent just remove the plug and drain it. lefty loosy righty tighty
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 05-30-2013, 07:03 AM   #3
1931 flamingo
1931 flamingo's Avatar
Yes, install 4 1/2 quarts of YOUR choice oil. Many different views on what type/brand to use. I use 30W. Do a search at top of page. Also suggest you get a copy of Les Andrew's book Vol 1, available from any of the vendor's and possibly amazon. Lots of good info. Al;so get some free catalogs from the vendors, there's a wealth of info in them also.
Paul in CT
Old 05-30-2013, 07:19 AM   #4
ctlikon0712
ctlikon0712's Avatar
A new engine takes 5 quarts but a half quart is retained in various places in the motor so it will take 4 1/2 on a refill. Also the change frequency is 500 miles because there is no filter and a few other reasons. It is just as important to lube the cars lube points properly and on a set schedule. Here is that info...
I got the lube chart from an owners manual that can be found here.
http://www.motormayhem.net/mode-a-fo...owners-manual/
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 05-30-2013, 08:33 AM   #5
V4F
V4F's Avatar
personally i would not use non-detergent oil . it causes sludge . new oils are just fine . i run 20/50 valvoline VR1
V4f
V4F is offline   Reply With Quote
Old 05-30-2013, 09:13 AM   #6
sethkestenbaum
sethkestenbaum's Avatar
Mike,
Good questions... especially if you have never changed the oil in your car. I received the following advice when I did my first oil change about 1.5 years ago.
If this is the first oil change on a "new to you" car, be certain to look at how opaque or transparent the oil is that drains. If it looks like chocolate syrup or is really gritty, it may be time to consider "dropping the pan" and cleaning out the valve chamber. If the oil looks like light or dark maple syrup, you are in good shape -- change it regularly and enjoy. If it looks milky, that is a different can of worms completely as you have water or coolant getting in there. If it has pieces of metal in it, call a mechanic!
Seth Kestenbaum
www.oldcarroadtrip.com
sethkestenbaum is offline   Reply With Quote
Old 05-30-2013, 09:21 AM   #7
bogdonj
bogdonj's Avatar
Should also note that when you loosen and take out the plug in the pan make sure you grab the small ring/washer that comes with it and don't allow it to fall into the oil catch bucket...done that and isn't fun. Also when tightening the plug don't over do it and strip the threads. If it's an older engine I run Shell Rotella 15W-40.
_________________________________________
1931 Ford Model A Tudor
1930 Ford Model A Deluxe Roadster
1930 Ford Original Rolling Chassis- Restoring
bogdonj is offline   Reply With Quote
Old 05-30-2013, 09:26 AM   #8
J Franklin
J Franklin's Avatar
If you can, find out what the previous owner was using for oil, that will tell you a lot.
Old 05-30-2013, 09:48 AM   #9
baquetA1929
baquetA1929's Avatar
As you can tell equals liters? "install 4 1/2 quarts"
"Los hombres cobardes ven la muerte muchas veces, los hombres valientes solo una"
"Siempre hay que tratar de ser el mejor, pero nunca creerse el mejor".
J.M. FANGIO
baquetA1929 is offline   Reply With Quote
Old 05-30-2013, 11:01 AM   #10
Dave in Boise
Dave in Boise's Avatar
I like the Delo 400 as it is a 15-40 weight and has some zinc in it as it was formulated for diesels.. Just remember, *any* oil is better than none at all
- Dave in Boise
Dave in Boise is offline   Reply With Quote
Old 05-30-2013, 11:46 AM   #11
James Rogers
James Rogers's Avatar
Wrong!
Old 05-30-2013, 11:49 AM   #12
James Rogers
Just drain the oil and replace it with enough to bring the level to half way between the F and the L. You may find it will only take 4 quarts to get to that point. Use any Diesel grade HD oil or if you don't want to use Diesel oil any kind of High Detergent is good. Non detergent oil is for lawnmowers and I don't even use it in mine.
Old 05-30-2013, 12:09 PM   #13
Hicktick
Hicktick's Avatar
Warm the engine up first , it will flow out better .
Hicktick is offline   Reply With Quote
Old 05-30-2013, 12:33 PM   #14
Purdy Swoft
Purdy Swoft's Avatar
I only put in four quarts when I change the oil. Ford recommended 40 weight for summer and 20 weight for winter. 20w40 should be good with todays multi viscosity oils. I've never been able to find a 20w40 oil. I use Walmart 20W50. I figure that the 50 weight will be good for the old engines for summer and the 20 will be good for winter so 20w50 works good for me. One of the members pointed out that the 20w50 Walmart oil is actually Mobil, this confirms that there is really no need to pay more for an advertised brand.
Old 05-30-2013, 01:36 PM   #15
Rock Hornbuckle
Rock Hornbuckle's Avatar
Thanks
Mike
YOUR favorite brand is recommended.
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls
'41 Fordor Deluxe / 2-duece flattie
'66 1/2 Dodge Charger
'14 100th Anniversary Challenger Limited Edition.
Semper Fidelis
Rock Hornbuckle is offline   Reply With Quote
Old 05-30-2013, 04:04 PM   #16
Msaby
Msaby's Avatar
Sorry I guess I should have been a little more specific as to what weight oil should be used. i didn't mean to create a debate between any members.
Old 05-30-2013, 04:06 PM   #17
Msaby
Msaby's Avatar
yea, I have had that happen to me a few times over the years.
Thanks
Mike
Old 05-30-2013, 04:09 PM   #18
Msaby
Msaby's Avatar
My father has owned the vehicle for maybe 15 years and hardly drove it. I would have been the one who changed the oil many years ago. The car has been sitting under a car cover for atleast 7-8 years now.
Thanks
Mike
Old 05-30-2013, 04:51 PM   #19
marc hildebrant
marc hildebrant's Avatar
Msaby,
I would urge you to get the Model A owners manual and other Model A books and THEN ask for help on the Barn.
In that manner, you can compare the answers....
Marc
marc hildebrant is offline   Reply With Quote
Old 05-30-2013, 04:52 PM   #20
Jordan
Jordan's Avatar
I have used 50w, 30w, 10w30, 10w40--- the point is, nothing's blown up yet! If you don't know what was used in it before, I would go with a 30 or 40w valvoline. Valvoline is the best oil on the market. Stay away from Penzoil. There's no need to change your oil every 500 miles with todays quality of oil. Any engine building will tell you about 1,000 miles without a filter, or 2,000 with a filter.
Cowtown A's
Jordan is offline   Reply With Quote
