06-23-2016, 07:15 AM | #1 |
Toein
Have any of you used the string method to set the toein on your model A?
06-23-2016, 07:31 AM | #2 |
Re: Toein
Only used a string as a quick check. I always use a gauge when setting the tow-in.
06-23-2016, 08:32 AM | #3 |
Re: Toein
The most accurate way to set the tow-in is to take the car to a front end alignment place that has the oldstyle equipment to set alignments manually. Here in Tulsa there is a place called Acme Wheel Alignment. They have the equipment to set large trucks and heavy vehicles. For a nominal price they have set my frontends first time/every time.
Don't go to a Firestone or similar place that has computerized/laser guided equipment. That won't work on the A. The old-time devices that are for DIY users usually don't take variations in the tire walls into consideration and can leave you way out of alignment. |
06-23-2016, 09:00 AM | #4 | |
Re: Toein
06-23-2016, 11:56 AM | #5 |
Re: Toein
One poster used 2 straight pins, into the tread rubber. Measured, rolled it forward, & measured again. Better than a SHARP stick in the EYE!
Bill W.
06-23-2016, 01:09 PM | #6 |
Re: Toein
The shops that have the less techy equipment work on heavy equipment that is relatively similar to the old ford setup. |
06-23-2016, 01:49 PM | #7 |
Re: Toein
I have used the string method with success.
06-23-2016, 01:56 PM | #8 | |
Re: Toein
06-23-2016, 03:03 PM | #9 | |
Re: Toein
06-23-2016, 03:38 PM | #10 | |
Re: Toein
Mitchs' Dad
06-23-2016, 03:41 PM | #11 |
Re: Toein
Cold??? It was 80° yesterday while I was out putting new tires on my truck.
06-23-2016, 03:51 PM | #12 |
Re: Toein
Dad thinks a bad idea, I agree Maybe u can get it transported down
OR Just use the shower rod and wing it, and say to yourself it's right on the money I know it is.. It becomes believable after a while |
06-23-2016, 04:05 PM | #13 |
Re: Toein
How would I get to Alaska I have no idea
Do I take a train, boat, plane or a submarine Or can I just drive up |
06-23-2016, 04:20 PM | #14 |
Re: Toein
Just follow the map:
06-23-2016, 05:46 PM | #15 | |
Re: Toein
Minnesota now has stealth mosquitoes. You can't hear them and you don't feel them. You have to just keep swatting. |
06-23-2016, 06:18 PM | #16 |
Re: Toein
When I finish this guys A I'm doing all that work on from the other thread I posted, I will be doing a computerized alignment on it. To compensate the sensors which detects wheel run out and the target mounting variation on the wheel you only have to roll the car forward about 6". Amazing isn't it...
06-23-2016, 06:34 PM | #17 |
Re: Toein
Sooooo, does that shower rod work or not? Based on another thread and it sounded like it does work, tomorrow I was going to get a rod and some stick on measuring tape.
06-23-2016, 07:18 PM | #18 |
Re: Toein
Yes, it works, and because the rod stays against the same spot on the tire it compensates for any bent rim or variation in the tire.
06-23-2016, 08:59 PM | #19 |
Re: Toein
Those Mosquitoes must be related to the ones in northern Michigan. They are so big they have to get a permit to land.
06-24-2016, 12:08 AM | #20 |
Re: Toein
