Old 07-20-2013, 11:09 AM   #21
John Kuhnast
Default Re: Opinion on Sears Allstate tires
Golden I had some old garfields they had numbers stamped in 2170 Made in the 21st week of 1970. Look on all the tires. the numbers are small and may have been rubed off. Mine were Whitewalls with the numbers on the black side.
John Kuhnast is offline   Reply With Quote
Old 07-20-2013, 12:06 PM   #22
Tom Wesenberg
Tom Wesenberg's Avatar
Originally Posted by Purdy Swoft View Post
I bought a NOS Allstate 19 inch tire on eBay a couple of years ago. I noticed that it was rayon cord instead of nylon. The tire looked perfect and was very plyable. I installed the tire on the spare tire mount of the speedster by hand with Go Jo. I aired it up to 35 PSI and went to wash my hands. Before I could wash the Go Jo off my hands, I heard a loud explosion, it was the NOS rayon cord Allstate tire.
When I bought my first complete Model A, I bought some good looking used tires at a swap meet. They had rayon cords and they all blew apart as soon as I aired them up. Then I called Coker Tire and had them bring 4 Insa tires to Iola for me. At that time they were about $50 each.
Old 06-30-2016, 05:36 PM   #23
mshmodela
mshmodela's Avatar
No clue to the age of my Sears Allstates, but they in the little over two years I've had the car they hold air great, show little signs of dry rot..
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 06-30-2016, 06:37 PM   #24
jim galli
jim galli's Avatar
Let's take your logic to it's "logical" conclusion. If old is bad . . . maybe you should re-think having a Model A at all.
He is no fool who gives what he cannot keep, to gain what he cannot lose... Jim Elliott, 1949
http://tonopahpictures.0catch.com
jim galli is offline   Reply With Quote
Old 06-30-2016, 07:03 PM   #25
Dick Steinkamp
Dick Steinkamp's Avatar
Originally Posted by John Kuhnast View Post
The date is on them even back then. its the week from 01 to 52 and the year.
"Tires Manufactured Before 2000 The Tire Identification Number for tires produced prior to 2000 was based on the assumption that tires would not be in service for ten years. While they were required to provide the same information as today's tires, the week and year the tire was produced was contained in the last three digits. The 2 digits used to identify the week a tire was manufactured immediately preceded a single digit used to identify the year."
http://www.tirerack.com/tires/tirete....jsp?techid=11
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 06-30-2016, 07:48 PM   #26
glenn in camino
glenn in camino's Avatar
The ones I had on my 29 phaeton back in the 80s lasted forever.
Old 06-30-2016, 10:31 PM   #27
racingrufus
racingrufus's Avatar
I have INSA tires on my 29 special coupe. These tires have tread and side walls look good and they hold air good. Tires were on car when I bought it. Tires have no date code. The only marking is Made in Chile. Who sold these tires in US. I have owned car for 5 years and have had no problems with tires but do not know how old they are. Thanks Dwayne
racingrufus is offline   Reply With Quote
Old 07-01-2016, 07:16 AM   #28
diomed
diomed's Avatar
My Allstate tires had EE97356Y stamped on them. It also has the "BOOL" hubcaps on it. Since those were available in the 1950's and it sat in a garage for 40 years, I'm guessing the tire code means 35th week of 1956?? Talk about antique tires!
Sent from my Nexus 9 using Tapatalk
kris
diomed is offline   Reply With Quote
Old 07-01-2016, 07:36 AM   #29
Jeff/Illinois
Jeff/Illinois's Avatar
diomed, do they have the 'original' air in them? I get a kick out of the auction houses that say things like that!
Old 07-01-2016, 10:49 AM   #30
Robert/Texas
Robert/Texas's Avatar
My Sears Allstate tires started shedding tread some years ago. I noticed that there was a seam across the tread where it was "welded" to the carcass. This is where they started coming apart.
Robert/Texas is offline   Reply With Quote
Old 07-01-2016, 03:21 PM   #31
Joef21
It's not usually the tire that's blows out but the tube inside. I would dismount the tires and check the tubes.
Joef21 is offline   Reply With Quote
Old 07-02-2016, 12:02 PM   #32
1929 essex
My 31 2dr sedan that I got in Feb 2016 has Wards tires and I haven't added any air since I added air the day I took it off the blocks it was stored on since 1971.
1929 essex is offline   Reply With Quote
Old 07-02-2016, 02:00 PM   #33
qstott
qstott's Avatar
I checked my Allstate tires today. They were nylon with date stamp of 108. From what the previous owner said, I think they were bought in 1988.
qstott is offline   Reply With Quote
Old 07-02-2016, 02:28 PM   #34
Roadster62
Roadster62's Avatar
I can still remember going to SEARS with Dad in 1962 to get the four wide white wall tires for his Roadster, still has two on the back. I should get it running again. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
