Old 03-25-2024, 06:39 AM   #1
ronn
Default winch
I know this is overkill- but just bought a 13k rope winch on ebay for under 250. delivered to my door in under 24 hours!
thought it was a great deal and glad to give the rope a shot. Tired of the metal burrs from the metal cable.
Never do know when your model A is caught down a ravine and will need that 13k pulling capacity!
lol
Old 03-25-2024, 09:01 AM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: winch
lol
We have been using the synthetic winch rope for probably 5+ years now and love it. On my Hauler, we 'overbuilt' the rear ramp door and so we had to use a winch to raise/lower it. It has a rating of like 8000#, and when the door is down, we can remove the hook and wad it up to store it out of the way. The same for floor winches on the race car trailer and my enclosed trailer. I also highly recommend these synthetic winch ropes.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 03-25-2024, 11:34 AM   #3
ronn
Default Re: winch
good to hear Brent. thanks for sharing. I had mixed feelings on which way to go.
Old 03-25-2024, 02:27 PM   #4
fried okra
Location: Daniel Island,SouthCarolina/Knoxville, Tennessee/Sanibel Island,Florida
Default Re: winch
Brent, tell us bout the race car you mentioned......inquiring minds wanna know
fried okra is offline   Reply With Quote
Old 03-25-2024, 02:33 PM   #5
Doug Linden
Doug Linden's Avatar
Default Re: winch
I was looking at the two types of winches and was wondering which way to go. Brent's experience has made my choice easy now.
Doug Linden is offline   Reply With Quote
Old 03-26-2024, 04:41 AM   #6
Rob Doe
Default Re: winch
This might be a good place to check out my winching question. I recently saw a photo of a Model A being winched ono a flatbed car hauler. The cable was attached to the middle of the front axle. Is the front axle capable of withstanding this? I would have used a strap at each spring perch???
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 03-26-2024, 05:07 AM   #7
ronn
Default Re: winch
makes much more sense. if the car snags on anything, you bend the axle at a single mounting point.
Old 03-26-2024, 08:42 AM   #8
Zax40
Zax40's Avatar
Default Re: winch
One thing to watch out for when using the winch rope is that it can retain moisture. Which isn't a big deal for the winch rope itself. But the drum of your winch can start to rust out.
If your winch is out in the rain regularly buy one of those winch covers.
Zax40 is offline   Reply With Quote
Old 03-26-2024, 08:55 AM   #9
51504bat
51504bat's Avatar
Default Re: winch
Maybe referring to the Model A in this post?
https://www.fordbarn.com/forum/showt...73#post2300073
Old 03-26-2024, 10:11 AM   #10
jeepguy1948
Default Re: winch
I have a ‘48 Willys CJ2 and have been using the rope for several years now and wouldn’t go back to steel cable if someone gave it to me. It is significantly more expensive but worth every penny (in my opinion).
jeepguy1948 is offline   Reply With Quote
Old 03-26-2024, 10:34 AM   #11
BRENT in 10-uh-C
Default Re: winch
Rob, this is likely one of those 'He said/She said' myths that someone fabricated and people bought into it because it was believable. The worst thing about attaching to the middle of the front axle is the risk of damaging the lower edge of the radiator apron. Outside of that, for no more than a Model-A weighs, with constant (-or somewhat jerky) pulling action, there is hardly any chance of bending the axle beam.
Some random pictures below. (FWI -we will be racing just east of Knoxville at Bulls Gap on April 5th & 6th if you are in the area.)
File Type: jpg 401489578_18401706394056723_2434842700839023161_n.jpg (73.3 KB, 22 views)
File Type: jpg 284289767_10224562128738449_252936020259841020_n.jpg (104.4 KB, 20 views)
BRENT in 10-uh-C
Old 03-27-2024, 12:06 AM   #12
Brad in Germany
Brad in Germany's Avatar
Default Re: winch
I really like my fully-enclosed, floor mounted, COMEUP rope winch in my enclosed trailer. The remote control on the winch allows me to be able to walk around and load the car by myself and the synthetic rope is so much easier to use than a steel cable. It is rated for 5000lbs, but does the job perfectly and being fully enclosed gives it a nice clean look while keeping dirt and water out of its mechanism and off of the synthetic rope.
Mac's Tie Downs make a really nice padded Y "Combo Bridle" specifically designed to go over the axel at both ends by the spring perches (use promo code "MACSPAT" for a $25 discount!). It is super easy and fast to put on and will not scratch your axel paint and also no worries about pulling the car by the center of its front axel nor possibly damaging the radiator splash apron:
Here is my floor mounted rope winch setup in my trailer hooked up to a 1929 Ford Model A using the Mac's Combo Bridle:
On the winch rope, there is a thick nylon sheathing to protect the rope from chaffing on the rear, beaver-tail flooring of the trailer, when the car being winched is on the ground, at the end of the loading ramp:
Brad in Maryland
File Type: jpg Screenshot 2024-03-27 at 12.46.49 AM.jpg (16.0 KB, 74 views)
Brad in Germany is offline   Reply With Quote
