Old 07-23-2016, 02:20 PM   #1
dbrist
Default 12v wiring diagram
I've been searching these threads for a while and I might have missed it, but I was wondering if anyone had a 12v negative ground wiring diagram
dbrist is offline   Reply With Quote
Old 07-23-2016, 03:02 PM   #2
Gary WA
Gary WA's Avatar
Default Re: 12v wiring diagram
No but in the Model A For Mechanics Handbook Vol. 2 shows it all.
www.whidbeymodelaclub.com
Old 07-23-2016, 03:05 PM   #3
dbrist
Thanks ordered it a month ago and still waiting
Old 07-23-2016, 03:09 PM   #4
Gary WA
Gary WA's Avatar
also How to restore your Model A. Vol 8 has info too.
Old 07-23-2016, 05:22 PM   #5
jrelliott
jrelliott's Avatar
Only difference between 6V positive ground schematic and 12V negative ground schematic is the polarity of the battery. Just have to repolarize the generator after changing the battery connections if you are going to use the same generator. Make sure you have negative ground alternator if using an alternator. The electrons do not care which way they travel. They just move from negative to positive.
Old 07-23-2016, 06:08 PM   #6
dbrist
Trucks already 12v system just like schematics to trouble shoot with
Old 07-23-2016, 06:54 PM   #7
Mitch//pa
Use this just switch the battery polarity around on the schematic
Old 07-23-2016, 10:50 PM   #8
Mike V. Florida
Mike V. Florida's Avatar
One only has to swap the wires on the ammeter and the coil to change the polarity.
To increase the voltage:
The coil needs to be changed or a ballast resistor added.
The horn needs a resistor or needs to be rewound.
Here is where we can get into a debate, one camp says leave the starter alone and the other says to have it converted to 12 volts. Take your pick.
Of course the bulbs have to be replaced.
Old 10-03-2017, 09:55 PM   #9
dogpatch31
im new..pls tell me the correct wiring for a 12V model A..what wires go where on coil?
dogpatch31 is offline   Reply With Quote
Old 10-04-2017, 12:20 AM   #10
Y-Blockhead
Y-Blockhead's Avatar
12v negative ground, battery positive to + side of coil, - side of coil to points (via switch). See Mike's post #8 above.
Old 10-04-2017, 05:28 AM   #11
Patrick L.
Patrick L.'s Avatar
Points are wired same as the battery. Whichever wire goes to ground from the battery goes to the points from the coil.
Old 10-04-2017, 01:37 PM   #12
Mike V. Florida
The point to point wiring makes no difference what the voltage the battery is.
Old 10-09-2017, 09:32 PM   #13
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
This is a complete discussion on converting to 12v as well as adding turn signals.
http://cedarcreekas.org/TechTopics/1...rn_Signals.pdf
Bill Lee
http://www.CedarCreekAs.org
BillLee/Chandler, TX is offline   Reply With Quote
Old 06-24-2020, 08:25 PM   #14
30AModel
I just made a 12v Negative Ground diagram after rewiring mine. This is a tried and tested diagram. Here is how you wire the ignition system. This diagram does not include lighting and horn.
NOTE: The Aftermarket "pop-out" style ignition cable connects to the "ON" position of the key switch. The "OFF" Position of the key switch connects to the NEG side of the coil. The key switch simply completes that circuit. DO NOT supply the "pop out" cable with 12v+!! Also in this diagram, you are looking at the BACK of the Ammeter where the studs are located. This diagram shows a GM 10Si one wire alternator, which self excites. Make sure you have a alternator that excites at LOW Rpm or it will not charge at idle. If you run a 3-wire alternator, DO NOT supply 12v constant to the exciter while the car is off. It WILL burn up!
30AModel is offline   Reply With Quote
Old 06-24-2020, 09:26 PM   #15
marc hildebrant
marc hildebrant's Avatar
30AModel,
You need to check your diagram as the ammeter is not connected and the alternator connects directly to the battery.
Marc
marc hildebrant is offline   Reply With Quote
Old 06-24-2020, 09:43 PM   #16
30AModel
The ammeter is connected to the distribution block and the main alternator lead connects to the Positive post on the starter, which in turn feeds back to the battery.
Old 06-25-2020, 09:51 AM   #17
Badpuppy
Ammeter originally was wired to show only battery current in/out. 30AModel moved it to the load side; it shows only "charge" of the entire load (minus coil) from alternator and/or battery. (I suggest moving coil to other side of block so its current will register also.)
Old 06-25-2020, 10:19 AM   #18
Ruth
And the coil.
Ruth
Old 06-25-2020, 01:33 PM   #19
Purdy Swoft
Purdy Swoft's Avatar
Don't forget to reverse the wires at the ammeter when changing polarity or the ammeter will read backwards .
Old 06-26-2020, 01:44 PM   #20
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Am I wrong?? The ampmeter has to have current flowing through it, or else how would it register current? If one side isn’t connected to anything, I fail to see how it would measure the current.
