04-15-2014, 07:24 AM | #1 |
H2O vs. Pre-Mix...???
It's time for me to get the coolant in the Coupe. I know this has been kicked around before, but I don't recall the conclusion if there is one.
Which is Best for Summer driving..? |
04-15-2014, 07:33 AM | #2 |
Re: H2O vs. Pre-Mix...???
In a properly working system anything that includes a rust preventive will work.
If are using antifreeze now why change just because the seasons changed?
04-15-2014, 07:44 AM | #3 |
Pre-mix will have distilled water in it, which is what you want to use when mixing your own.
The cost difference won't be that much if you have to buy distilled water. So it is up to you how much work you want to put into it. As Mike stated, either one will work that has rust preventive in it. Its the quality of the water that makes the difference.
Ron/IA 1929 Fordor Steelback Hawk A Model A Ford Club http://hawkamodelaclub.org/ |
04-15-2014, 09:38 AM | #4 |
50-50 mix is good if you live in a climate that gets freezing temps. You can run it year-round. However, if your block or head gasket allow coolant into the motor oil, you've got a serious problem.
It doesn't get below freezing where I live except for one or two months out of the year, but I still run 50-50 mix for the peace of mind. However, since I am going through break-in on a new rebuild right now (and re-torquing the head every 100 miles), I am running distilled water with a little soluble oil in it. Just enough oil so the water begins to look a little milky, that's all you need. After the head re-torquing phase is complete, will be switching to 50-50 mix again. |
04-15-2014, 10:34 AM | #5 |
Antifreeze leaks in places that water doesn't. Water cools much better than antifreeze. Antifreeze has a higher boiling point. I can't see how a higher boiling point helps with an unpressurized system. If the temperture is high enough, the engine will be running hot whether its boiling or not. Model A's shouldn't be compaired to modern cars with pressurized cooling systems that are designed to operate at higher temperatures. Model A's only have 14 head studs. That is even less than the tiny 60 horse flathead V8 engine had on one side (17). The model A head has been shown to teeter on the block as the engine runs. Blown head gaskets and gasket filler weeping on the left side is very common. Antifreeze only compounds all of these problems. If antifreeze enters the crankcase its good bye babbitt bearings!!!!!!! Model A's mark their territory with coolant out the overflow pipe after the engine is shut down and temps increase. If pets drink the coolant, it kills them. It killed my chow named chewy. If you want to use distilled water, it can't hurt anything but your pocket book and not that much. I've used mostly tap water for 54 years with no ill effects I do use waterpump lubricant mostly to quiet the water pump. Water pump lubricant also hinders cooling but not enough for concern if too much isn't used. Antifreeze is only good to prevent freezing with the model A. The probable side effects of antifreeze out weigh any benefit of running antifreeze in the model A for year round use. If I lived where it was a danger of freezing for most of the year, I might run antifreeze year round. The winters are mild here in south west Alabama. Just my thoughts and reasons why.
04-15-2014, 11:46 AM | #6 |
Mike Cleveland, Ohio |
04-15-2014, 03:26 PM | #7 |
In the old cars I prefer distilled water and a heftily dose of 'anti-fur' [rust] inhibitor. I never did figure out where that term came from.
04-15-2014, 03:38 PM | #8 |
I ran a 50/50 mix of Prestone and distilled water, year round for 28 years and never had a problem.
Anyone remember this stuff ? Last edited by Mikeinnj; 04-15-2014 at 03:47 PM. |
04-15-2014, 03:58 PM | #9 |
Before antifreeze didn't they use alcohol to prevent freezing? If so did that leak in places that water would not?
04-15-2014, 05:35 PM | #10 |
50/50
04-15-2014, 05:57 PM | #11 |
My Dad use to tell me that even kerosene was used as a coolant in the colder parts of the country when nothing else was available.
04-15-2014, 06:00 PM | #12 |
two things, 1-if water is getting into the crank case it doesnt make much difference if it has anti freeze in it or not, you have major problem, 2- anti freeze has an anti rust properties and water pump lube in it, ive heard all the reasons for not using anti freeze, most were mentioned in this post, ive also seen the damage done to engines with out it from freezing in the winter months, if you have a coolent leak, dont blame the anti freeze, find and fix the problem, probably warped head or engine deck not straight, and improper installation of the head gasket, not knowing how to torque , improper torque value, improper torque sequence or not retorquing often enough, so dont put all the blame on the anti freeze
04-15-2014, 06:11 PM | #13 |
Anti freeze destroying the Babbitt and more prone to leaking is bunk along with using just distilled water.
Distilled water will leach metal and minerals from the block till it reaches a PH balance point. Save the distilled water from for the battery and use good filtered water. Too much straight water in the in the crankcase or anti freeze will do the same thing, wash the oil out of the bearings. There have been test done soaking Babbett bearings in straight anti freeze and no damage done to the Babbett. The only reason you think anti freeze is more prone to leaking is because it's colored and you can see it, water leaks form the same places but evaporates before you see it. I run 50/50 all year for cooling in the summer and freezing in the winter and water jacket protection all year. |
04-15-2014, 07:22 PM | #14 | |
The more pure water is, the more "empty" is is, and water doesn't stay empty - it WILL dissolve something, until it's no longer empty. 50/50 coolant and tap water (we have very good water here) is all I use, have done in a LOT of cars, for years.
Allan '29 Tudor, Canadian RHD Whangarei, NZ "Duct Tape can't fix stupid, but it can MUFFLE the sound" |
04-15-2014, 08:25 PM | #15 |
I agree with Purdy 100%
04-15-2014, 08:28 PM | #16 | |
04-16-2014, 10:25 AM | #17 |
Why pay the big companies to "MIX" your antifreeze for you ? That's just a marketing scheme to get more of your money. Mix your own.
MIKE (mikeburch) |
04-16-2014, 11:06 AM | #18 |
its actually cheaper to buy it premixed
04-16-2014, 11:31 AM | #19 |
To tell the thruth, I have not priced it.
For 50-50 mix to be cheaper, TWO mixed-gallons of it would have to be cheaper than ONE gallon of non-mixed, to get the same amount of antifreeze. Am I missing something ? MIKE (mikeburch) |
04-16-2014, 11:33 AM | #20 |
Look again & do the math:
1 gallon of 50/50 premix for $14. 1 gallon straight for $16, which will make 2 gallons of 50/50 which brings the price down to $8/gallon
