Old 01-03-2014, 09:09 PM   #1
Brother Hesekiel
Brother Hesekiel's Avatar
Default Bratton's Model A tubes
Following the advice I received on this board, I ordered the Model A tubes in 19" size with rubber stems from Bratton's.
Today I went to the tire store to have the first 2 tires fitted (I prep and paint one wheel at a time -- slowly), and the tire mounting professional pointed out that the valve stems in the tube are too thick for the hole. He's half correct, as we were able to push the valve stem through about 95%, but it's tighter than I would have expected. Let it be known that I had stripped the rims of all paint and just painted them "normally," so there's no excessive built-up on them. Is that a common problem, something I should ignore, or should I enlarge the valve hole in the rims a bit with a file for the remaining 3 wheels?
Brother Hesekiel is offline   Reply With Quote
Old 01-03-2014, 09:18 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Bratton's Model A tubes
Well remember, YOU are the one that is putting the incorrect valve stem in the hole, --Not Brattons.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-03-2014, 09:26 PM   #3
wrndln
Ford used metal valve stems that fit the holes in the rims fine. I have mounted 2 sets of tubes and tires with metal valve stems. I cut off the rubber stems of both sets (that hurt) and installed the metal stems. It wasn't as bad a job as I though it would be. The metal stemed tubes fit great and look very nice. If you don't what to go the metal stem route, I guess you could carefully "grind off some of the outside of the rubber stems near the main part of the tubes. If I remember correctly, there was quite a bit of rubber around the metal core in the rubber stem. Hope this helps.
Rusty Nelson
Old 01-03-2014, 09:48 PM   #4
31pickup
HI,
Just mounted 6 rubber stem tubes from Brattons with no problem.
31pickup
31pickup is offline   Reply With Quote
Old 01-04-2014, 12:41 AM   #5
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I culd "DOGONE" do it, iffin' I had THUMBS, it ain't the end uf the WURLD, to modify sumptin' Be yo' own man & DON'T let folks WURRY or INTIMIDATE you, it's yo' OWN car, Brother!
Ol' Bill even drilled a NON-FACTORY HOLE in Vermin & slept like a SNORING OOOOLD BABY thet night!!
BusterT.
"THE ASSISTANT GURU OF STUFF"
Old 01-04-2014, 12:48 AM   #6
700rpm
700rpm's Avatar
Use a little Vaseline and they'll slip right through.
Ray Horton, Portland, OR
Old 01-04-2014, 04:41 PM   #7
1967 Ford
That's what she said......
1967 Ford is offline   Reply With Quote
Old 01-04-2014, 04:46 PM   #8
MrWzrd
Originally Posted by 31pickup View Post
HI,
31pickup
The pickup is a dually?? I want one!!
MrWzrd is offline   Reply With Quote
