11-30-2012, 07:43 PM | #21 | |
Re: 289 or 352 engine?
Doesn't matter what the VIN code is because that engine could have been swapped in at any time . That was done a lot back then . Jim |
12-06-2012, 12:39 PM | #22 | |
Here is one way I did it take a pencil into the plug hole at the lowest mark the pencil at the highest mark the pencil measure in between. if it is 4 inch its a 390 3and 3/4 352 |
12-12-2012, 02:56 AM | #23 |
Best advice I can give you is buy this:http://www.mre-books.com/interchange/index.html since you have a limited knowledge of Fords this will be the best investment you can make on your Ford,clicking on the sections in blue to the left will give you a preview of what is inside.
