01-20-2017, 04:22 PM | #1 |
Radius Cross pin
Removed my front end. I had to cut bolts off as there was no retaining pin. I ordered a new kit and just want to know how the pin is installed. I see the cross cuts in bolts. Do you just slide it in between them?
01-20-2017, 04:31 PM | #2 |
Re: Radius Cross pin
Yes, From the outside of the bell housing.
Good day! |
01-20-2017, 05:43 PM | #3 |
When you install the 2 bolts, then the crosspin, push up and down on the two bolts to check for end play. Sometimes the bolts pockets get so worn that the bolts sink too far down and the crosspin can't hold the bolt slot from turning. This condition will also allow more slop on the spring loaded ball cap.
If the pockets are too worn, then just make some small diameter washers to fit under the bolt heads. The easiest thing to do is take washers that fit the shaft snugly and turn or grind the OD to the head diameter. |
01-20-2017, 05:43 PM | #4 |
This is how it looks from the inside.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 Last edited by 1955cj5; 01-20-2017 at 05:56 PM. Reason: Picture |
01-20-2017, 05:51 PM | #5 |
thanks, guys! I notice that pin has a hole in it from the vendors. does a cotter lock it in somewhere?
01-20-2017, 06:00 PM | #6 |
01-20-2017, 06:04 PM | #7 |
Cotter goes into pin (rod) and enters into? Sorry..
01-20-2017, 06:13 PM | #8 |
The cotter pin goes in there just to keep the "pin" from creeping out of the bell housing.
01-20-2017, 06:27 PM | #9 |
ok, gotcha! Thanks guys!
01-20-2017, 08:18 PM | #10 |
Dont forget the thick felt pad
