01-20-2017, 07:26 PM | #121 |
Re: Pulled my spare engine apart for inspection
Isn't that the truth. I was recently given an engine that has been a club member's "spare" for ~40 years. He said it came with his car and has been sitting in his garage all this time.
01-20-2017, 08:06 PM | #122 |
01-21-2017, 12:15 PM | #123 |
01-23-2017, 07:26 PM | #124 |
Brumfield head installed, started right up. Seems to run about the same, sounds the same to me.
https://www.youtube.com/watch?v=UABt...ature=youtu.be |
01-23-2017, 07:35 PM | #125 | |
All steel from pedal to wheel |
01-23-2017, 07:44 PM | #126 |
01-23-2017, 07:57 PM | #127 |
01-23-2017, 09:15 PM | #128 |
Yep, $25 bucks. He had several stock heads too. He knew it was a high compression head, I even remarked to him that a Synders 5.5 was $300. And asked if he was sure he wanted to part with it. A stock head would have been fine with me, but since he didn't care I thought it would be an interesting experiment to try it out. It certainly didn't fit down over the studs as well as the one I pulled off, and the distributor seems to set a wee bit higher making the spark-plug wires seem a tad too short. I took a peek at the honing marks in the cylinders while I had the head off, they are still there for the most part but you can tell it is wearing in. He has a Fordor for sale for $5000 too if anyone's interested. A pretty complete car that does run and drive.
01-24-2017, 05:42 PM | #129 |
CHA-CHING! Maybe a little more with some run time on it?
76,75,75,75. |
