02-03-2014, 12:12 AM | #1 |
Suggestions wanted on testing an engine not on a frame
Have any of you have built some kind of home-made frame on which you could mount an engine and test-run it safely?
02-03-2014, 12:29 AM | #2 |
Re: Suggestions wanted on testing an engine not on a frame
Many have, some use an old cut frame, some modify a shopping cart so they can wheel it around. The limit is your imagination and what you have on hand.
This is from TK in LA
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 02-03-2014 at 12:39 AM. |
02-03-2014, 12:48 PM | #3 |
What Mike just pictured is exactly how I'd make one. It does the job safely, is easy to make, and doesn't take up much space.
02-03-2014, 01:43 PM | #4 |
Beware of torque reaction! Quite a few auto engines have been flipped sideways with their run-in stands by abruptly opening or closing the throttle. A temporary outrigger clamped to each side of the stand base and extending out would be prudent. A 6' 4x4 and a couple heavy C clamps would suffice for an A. Just a thought.
02-03-2014, 01:47 PM | #5 |
It is easy to build a test stand.
1928 Model A Business Coupe Rebuild picture gallery here The light at the end of the tunnel has been turned off due to budget cuts. |
02-03-2014, 01:48 PM | #6 |
02-03-2014, 01:55 PM | #7 |
many people build stands if you belong to a local model a club maybe a member would lend it to you!!!
02-03-2014, 02:44 PM | #8 |
That's pretty neat, but I can't figure out what you've got your gas tank stand bolted to.
02-03-2014, 03:12 PM | #9 |
I have seen engines run in a big truck tire. Put the oil pan down in the center and it just rests in there. Obviously not the safest option, but it seems adequate.
02-03-2014, 05:24 PM | #10 |
02-03-2014, 05:27 PM | #11 |
It ran a old hay baler. But will be my engine stand.
02-03-2014, 06:46 PM | #12 |
That's a good one too. Do you suppose they cranked it to start it?
02-03-2014, 06:57 PM | #13 |
No it starts with the key. It's like the took all from the firewall forward and used it. Has a model a transmision on it allso. And the thing to put the belt on after it.
02-03-2014, 08:18 PM | #14 |
I see the belt pulley, but I don't see a starter.
02-03-2014, 10:46 PM | #15 |
The old guy said he took it off. He said he had it rebuilt to use a tractor shows.
02-03-2014, 10:55 PM | #16 | |
Bill Worden 1929 Roadster 1929 Briggs Town Sedan 1930 Closed Cab pickup Smith Motor Compressor 1951 Ford F1 High Desert Model A's |
02-04-2014, 12:32 PM | #17 |
Here are some other pictures of my test stand that is a work in process. Made from all scrap material, mostly 1/4 and 3/16 in steel. It is about 2ft wide, 33" long and about 25" from the ground at the rear motor mount. The stand is high enough to allow your cherry picker underneath. Space on the side holds the battery and misc. tools still allowing room to remove the pan if desired or just changing the oil. Very stable and have never had an occasion for it to torque or try to tip over. Maybe with a blower at full throttle but for a standard A motor, no problem. I've added a step down for the Radiator to allow for use of my 30/31 radiator with a 28/29 top neck. Any questions? More Pictures? Dimensions?
02-04-2014, 12:49 PM | #18 |
Heres mine. I would be the shopping cart guy.
02-04-2014, 01:26 PM | #19 |
I was at Fred Heidricks by Woodland CA, years ago, where they have a large collection of machines and he showed me a thing he made to crank an engine .It was a electric motor with a gear box and a crank to fit the engine mounted on a stand with wheels to move it around . When he hit the switch the motor would turn over .I have a 3/4 HP drill that I put a crank in it to fit my A and ran my engine to brake it in and this engine was hard to crank by hand .
02-04-2014, 01:40 PM | #20 |
I've got one in a stand similar to the gleaner shown above but mine sets lower to the floor. Works like a champ. I had to build a frame to hold the gas tank and wiring.
The most difficult part of setting it up is attaching a muffler. The comment about torque is valid but with mine setting lower it is less of an issue. Had mine running and idling with a full weight flywheel attached just a few days ago. |
