Old 11-05-2020, 02:19 PM   #1
jerry shook
Default Master cylinder
I have a 31 A with the master cylinder on the right side. Is this done on a lot of cars. Don’t have good brakes. everything has been put on new. Photos or any help would be appreciated.
jerry shook is offline   Reply With Quote
Old 11-05-2020, 02:46 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Master cylinder
There was a recent thread on this (maybe yours??) with the pic you want.
Many conversions were done this way using the brake cross shaft. Do you have 39-42 backing plates or the easier to adjust 42-48's??
Paul in CT
Old 11-05-2020, 03:05 PM   #3
Charlie Stephens
Without seeing it I would suspect the leverage of the linkage. When you push the pedal how much does the rod at the master cylinder move? When you say you don't have good brakes what are they doing? Any photos?
Charlie Stephens
Old 11-05-2020, 06:13 PM   #4
jerry shook
I did put a thread. Just trying to get more info. Charlie you wrote about leverage of the linkage. I will look tomorrow morning to see how for the rod is going into the cylinder that may be my problem. On having good brakes the peddle goes nearly to the floor pumping don’t do any good it will stop but not good enough to trust driving. Don’t know how to send pics. The plates are 40. How much should the rod move. Thanks everyone.
Old 11-06-2020, 08:41 AM   #5
1931 flamingo
Have you adjusted the brake shoes?? New shoes?? Bled the system?? Maybe 1/8" brake rod clearance.
Paul in CT
Old 11-06-2020, 12:22 PM   #6
Charlie Stephens
Were they good at one time and then went bad?
Charlie Stephens
Old 11-06-2020, 02:28 PM   #7
jerry shook
Charlie the car was did not have good brakes when I bought it. All the brakes except the metal lines I have put on new adjusted bled an rod clearance.
Old 11-07-2020, 12:25 PM   #8
katy
katy's Avatar
What kind of master cylinder does the car have? Maybe it's undersize?
Old 11-07-2020, 07:43 PM   #9
jerry shook
Katy. The master cylinder is for a 40 ford.
Old 11-08-2020, 02:55 AM   #10
Chris Haynes
Chris Haynes's Avatar
A Ford Truck master cylinder has a larger piston.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 11-08-2020, 03:55 PM   #11
jerry shook
Chris would the larger piston push more fluid or more pressure to the wheels. An how for should the rod go into the master cylinder.
Old 11-08-2020, 04:06 PM   #12
Gary WA
Gary WA's Avatar
Model A Ford Mechanics Handbook Vol 2 by Les Andrews excellent with parts needed How to install etc. Hydraulic Brakes.
www.whidbeymodelaclub.com
Old 11-09-2020, 02:51 AM   #13
Chris Haynes
Larger piston = more volume. Bolts on exactly like the passenger car cylinder and looks the same.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 11-09-2020, 08:35 AM   #14
1931 flamingo
Do you get a hard pedal after bleeding?? Which backing plates do you have?? 39-42 or 46-48?? Wheel cylinders mounted correctly?? Go to the V8 forum and search : Brake Adjust.
Paul in CT
Old 11-09-2020, 09:34 AM   #15
Nosetime
Nosetime's Avatar
After toying with that idea and not feeling comfortable with the geometry, I went with Daves battery box set up, dual Mustang master is hard to beat.
Nosetime is offline   Reply With Quote
