Old 10-30-2020, 06:48 PM   #1
jerry shook
Default Need pictures.
Looking for pictures of how the master cylinder is installed when changing to hydraulic brakes. Appreciate your help. 31 model A coupe.
jerry shook is offline   Reply With Quote
Old 10-30-2020, 08:16 PM   #2
31Abone
31Abone's Avatar
Default Re: Need pictures.
Don't need hyd brakes..use stock set in good shape and add floaters ..going to a lot of work for little gain ..sc
31Abone is offline   Reply With Quote
Old 10-30-2020, 08:28 PM   #3
PalAl
PalAl's Avatar
This might help..............
https://www.lainefamily.com/ModelAFi...akeUpgrade.htm
PalAl is offline   Reply With Quote
Old 10-30-2020, 10:26 PM   #4
Chris Haynes
Chris Haynes's Avatar
Cling's makes a wonderful master cylinder kit that bolts in to your car. No butchering necessary. http://www.clingsaftermarket.com/add...=5000&subcat=1
1921 Runabout
1930 Tudor
Early 1930 AA
Old 10-30-2020, 10:56 PM   #5
Synchro909
Synchro909's Avatar
What limits the braking of a Model A is the small area of contact between the tyre and the road, not how the brakes are applied. The original setup can lock the wheels and decent speed on dry bitumen so how will locking them hydraulically make any difference?
As has been said, a lot of work for not much gain, even a deficit if the car is not used much because hydraulics can seize up through lack of use.
Old 10-31-2020, 07:23 AM   #6
1931 flamingo
1931 flamingo's Avatar
All the OP asked for was a picture, not opinions. Thousands of Model A's and 32-38 Fords have been converted to hydraulic with few of the problems always listed, Chevy and MoPar did it even earlier. JMO
Paul in CT
Old 10-31-2020, 07:31 AM   #7
Big hammer
Paul in CT
I agree with your first sentence ! And have no comment on the last sentence.
get a bigger hammer tap done
Old 10-31-2020, 08:26 AM   #8
big job
big job's Avatar
One must understand the difference between a brake rods and brake lines !
I do not consider my wifes 2015 a classic or a antique but her close encounter
coming to a red light and bong brake pedal to the floor her quick thinking
was emergency brake which is mechanical thats positive. A side from rust
prone brake lines, she blew a brake hose. In my book, these hoses are no
where the quality of real hydraulic hoses.
big job is offline   Reply With Quote
Old 10-31-2020, 08:33 AM   #9
Mike Peters
Mike Peters's Avatar
https://www.fordbarn.com/forum/showt...draulic+brakes
Mike Peters is offline   Reply With Quote
Old 10-31-2020, 08:33 AM   #10
jerry shook
Good Morning. I bought this A with hydraulic brakes on it. If it had A brakes I would have put Flat head Teds energize on it . I have two A with them an work great. This cars master cylinder was put on the rt side don’t as me why I don’t know trying to fix it right. Just trying to find out the best way. Thanks for your help.
Old 10-31-2020, 01:36 PM   #11
1931 flamingo
Many mount the M/Cyl on the right side and use the original cross shaft to actuate it.
Paul in CT
Old 10-31-2020, 03:17 PM   #12
jerry shook
Thanks Paul. If anyone has pics of how they are mounted on the right side please post them. Or tell me how they are done. I appreciate your help.
Old 10-31-2020, 03:32 PM   #13
jerry shook
Chris Haynes. I see you have an A with the master cylinder on the Rt side could you post more pics. Thanks.
Old 10-31-2020, 04:00 PM   #14
Bob Johnson
Bob Johnson's Avatar
Here you go.
Bob Johnson is offline   Reply With Quote
Old 10-31-2020, 05:19 PM   #15
jerry shook
Bob what size lines do you use. I think the ones on my car is 3/16th. Some one told they were to big.
