07-21-2010, 12:05 AM | #1 |
AR gas pedal spring
Can someone post a closeup of what the spring is supposed to look like for this AR gas pedal setup? The spring broke before I got a chance to look at it and the repro springs don't work as they are designed for the later design.
Here is mine with the repro spring on it not working: For reference, here is the later model design that the spring is designed for. |
07-21-2010, 09:58 AM | #2 |
Re: AR gas pedal spring
I should have a good one at the house. I'll look tonight when I get home and see if I can't get you a good photo.
Deron |
07-21-2010, 08:32 PM | #3 |
Here ya go... I hope these help.
Deron This is the assembly in the relaxed position with the lever point upward: This is with the lever pulled around against the spring, as installed in the car and viewed from behind: View from the front: And from the bottom: |
07-21-2010, 08:37 PM | #4 |
