11-12-2022, 09:30 PM | #1 |
Distributor cam screw
I want to set the point gap and set the timing on my A that i bought a month ago. [COLOR="Black"]Cannot get the Distributor cam screw loose. Probably hasn't been adjusted in years. I sprayed it with WD40. Put the cam wrench on it and tried to loosen the screw. Nothing. I'll try it again tomorrow. Any tips? If I can't get it loose do I need to take the distributor apart?
Thanks. |
11-12-2022, 09:32 PM | #2 |
Re: Distributor cam screw
Its a '29 Roadster.
11-12-2022, 09:38 PM | #3 |
I'd recommend using the largest flat blade screwdriver you can find that the blade will fit nicely into the slot of the screw and put some muscle on it. If that doesn't work, then you may have to resort to using one of these...
https://www.northerntool.com/shop/to...tid=pla-110031 |
11-12-2022, 09:40 PM | #4 |
Large screw driver bit in a 3/8" drive socket. One hand palm down on top of socket. Other hand on a breaker bar. Leverage is your friend.
11-12-2022, 10:01 PM | #5 |
I would remove the distributor and place it in a vise then try using a small impact gun while holding the cam with a visegrip plier. If the cam gets damaged it can be replaced with a new one.
11-12-2022, 11:04 PM | #6 |
11-12-2022, 11:34 PM | #7 |
J Franklin’s method is what I’ve done, keep downward pressure on the driver. You don’t have to hold the cam when loosening the screw. Get some better penetrating oil, I like PB blaster
11-13-2022, 12:53 AM | #8 |
The tang on the end of the distributor shaft can be damaged. Putting the shaft in a vise would be my approach. If the distributor won't pull out of the head, then vice grips on the cam would be my next step.
11-13-2022, 10:20 AM | #9 |
All good tips. Thanks. A thicker bladed screwdriver would help. I agree, more leverage is needed. I love my breaker bar when its time to take off lug nuts. I'll put it to use here too.
11-13-2022, 10:54 AM | #10 |
Realize it would be some down time and require a parts order, but if you damage the tang on the distributor shaft by loosening the cam, it should be replaced anyhow. I'd rather know that while I'm doing a tune-up in my garage than to have it leave you stranded on the side of the road.
11-13-2022, 11:06 AM | #11 | |
11-13-2022, 12:32 PM | #12 |
The link takes me to and impact driver.
11-13-2022, 03:25 PM | #13 |
Please do not use the impact driver that you smack with a hammer. Very good chance you will break the cast iron casting of the distributor. Better choice is get a hex nut that fits a 5/16" thread and which a 1/2" wrench will fit. Place the nut atop the screw and a quick simple mig weld thru the center will fix the nut to the screw and the heat created by the weld will help greatly to loosen the screw.
11-13-2022, 03:42 PM | #14 |
Do you have a air compressor and a impact wrench?
11-13-2022, 03:53 PM | #15 |
Unless you put it in, could be someone could not keep it tight because it was missing the lock washer and used loctite.
11-13-2022, 04:12 PM | #16 |
11-15-2022, 02:59 PM | #17 | |
Originally Ford had a thin flat washer and a thin lock washer. If you leave out either one the screw bottoms out in shaft and cam never gets tight. |
11-15-2022, 03:11 PM | #18 |
Note the SOME newer repro ( thin flat washer and thin lock washer )
has been replaced with one lockwasher that is as thick as the lock washer and flat washer together. Last edited by Benson; 11-18-2022 at 11:50 AM. |
11-17-2022, 10:43 AM | #19 |
Use heat from a propane torch on the head of the screw, then let it cool, then repeat several times. Then apply some penetrating oil (after it cools). Then it may come off. Do not use excessive force where you damage the screw slot (as others have said, the screwdriver should fit in the slot snugly). If this process does not remove the screw, then drill the screw out gradually until the head pops off.
11-17-2022, 08:40 PM | #20 | |
Terry |
