Old 08-22-2012, 07:28 PM   #1
Pat Martone
Pat Martone's Avatar
Default How do you fix e-brake that pops-off occasionally?
My emergency/hand brake occasionally releases itself with a slight snapping sound.
I assume this means I need a new pawl or a new ratchet gear?
Thanks.
Pat Martone is offline   Reply With Quote
Old 08-22-2012, 08:15 PM   #2
ford1
Default Re: How do you fix e-brake that pops-off occasionally?
thats what it looks like , pull it and find the problem
ford1 is offline   Reply With Quote
Old 08-23-2012, 06:25 AM   #3
Aerocraft
Aerocraft's Avatar
The engaging teeth will wear. It has been my experience that carefull "dressing" of the gear teeth will often resolve the problem. Gar Williams
Aerocraft is offline   Reply With Quote
Old 08-23-2012, 01:09 PM   #4
Pat Martone
Thank you!
Old 08-24-2012, 01:38 PM   #5
1928Pickuppain
1928Pickuppain's Avatar
ya i just took the rachet gear off the lever and dressed the rounded tip pack to a point good as new.
1928Pickuppain is offline   Reply With Quote
