Old 07-10-2014, 11:08 PM   #1
jackson32
Default can you tell original tin from repop tin
I have a splash apron from a 32 ford 4 door a little bent up but good body man could straighten easily can or how to tell old original pieces from repop tin or is it imposable to tell Thanks in advance
jackson32 is offline   Reply With Quote
Old 07-11-2014, 08:24 AM   #2
Dave Mc
Dave Mc's Avatar
Default Re: can you tell original tin from repop tin
Some replacement 33/34 pieces have a Larger Bead ( Edge with Wire ) on fenders and tank cover than the Originals
Any man who thinks he can be happy and prosperous by letting the Government take care of him, better take a closer look at the American Indian!" - Henry Ford
Dave Mc is offline   Reply With Quote
Old 07-11-2014, 08:27 AM   #3
Lawson Cox
Lawson Cox's Avatar
Thinner metal a lot of times. Lines not as crisp on repop.
Old 07-11-2014, 09:22 AM   #4
DICK SPADARO
It is easy to spot the off shore radiator splash by aligning it in correct index and checking the slant of the central angle of the pan. If this is an original the metal will be slightly thicker and the central angle formed by the stamping will not be vertical like a stock panel and the central angle form when stamped will taper off to the side flaps not be vertical as original. Second place to check is the fender to side flap captured nut where the splash apron and the fender join up near the radiator. If the captured nut is like a pop rivet threaded insert it is a repo part. The captured nut on a stock apron is a threaded nut that is spot welded to the side ear flaps
dickspadaro.com
DICK SPADARO is offline   Reply With Quote
