07-14-2013, 08:38 PM | #21 |
Re: Dry lubricant for leaf springs
"Originally Posted by Rich in Tucson
For those of you who have used any form of brush or spray-on dry film lubricant (particularly spray Slip-Plate which I have): A - Did you paint the springs before coating? B - Did you paint the springs after coating and assembly? If B, how did you keep the Slip-Plate from the spring sides or can it be painted over? I was planning to assemble cleaned leaves, paint springs as an assembly, then disassemble to apply the Slip-Plate, or is that unnecessary work? Thanks." A- No B-Yes As noted in an earlier post, I use ZepDryMoly on the spring rub surfaces and wipe the surface to be painted with lacquer thinner before painting. The overspray will come off easily. ZepDryMoly is far superior to graphite sprays because of the molybdenum disulfide in it. It can be obtained many places including Amazon. http://www.amazon.com/ZEP-Dry-Moly-F.../dp/B00C6Q5EZM |
07-14-2013, 09:01 PM | #22 |
I would only paint the friction surfaces with the coating you use. Then I would assemble the spring and paint it as an assembly. Do not know that this is the best technique, however.
07-14-2013, 09:04 PM | #23 |
Oklahoma City Model A Restorers Group. |
07-14-2013, 10:22 PM | #24 |
I did not paint the springs before coating. I painted the assembled spring after coating. I brushed the slip glide graphite on and only wiped the excess off the outside of the assembled spring. I painted right over the areas that had graphite residue. It looked great, the spring s ride better than any I have done another way. I will do all of mine this way from here on.
07-14-2013, 11:08 PM | #25 | |
By the way, I used to race midgets also. |
07-15-2013, 05:54 AM | #26 |
07-15-2013, 10:52 AM | #27 | |
07-15-2013, 11:41 AM | #28 |
They sell the spray as well as the roll on quarts. I prefer the quarts and use a 3 inch roller.
07-15-2013, 12:14 PM | #29 |
This is what I did, front and rear, (Teflon, not midgets.... )
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain. It is the very things that we think we know, that keep us from learning what we should know.- Unknown |
07-15-2013, 01:54 PM | #30 |
07-15-2013, 04:00 PM | #31 |
On my 34 which rode like a dog,I took the springs apart,cleaned them,layed chassis grease between each leave and put graphite powder in between each leave as well,the assembled the spring and wrapped it in DENSO tape,it now rides like a dream.
Lawrie |
11-14-2013, 08:23 AM | #32 |
After reading so many opinions on the various posts here is what I conclude:
1. Disassemble and wire brush well 2. Relieve the sharp edge on the ends of each leaf with a grinder 3. Brush on a coat of "Jasco Metal Prep" per instructions 4. Spray on a very light coat of primer (etching is what i use) 5. Brush on a good coat of "Slip-Plate" on the mating surfaces only 6. Assemble and finish spray the unit the color of your choice |
11-14-2013, 01:14 PM | #33 | |
Keep V-8ing and 4-banging!
She just don't have the appetite For gas somehow, And Dad, I got four carburetors Hooked up on it now. I tried to hook another To see if I'd do a little good, But ain't no place to put it 'Less I perforate the hood. Wanted, lower side sections of 32 radiator cowl. |
11-14-2013, 02:41 PM | #34 |
My mentor, an old time mechanic, taught me a trick about squeaky springs. Unload them until you get a gap between the leaves and put a penny on the bearing spot. No squeak! Better hurry though, Canada just did away with pennies, can the US be far behind?
11-15-2013, 08:00 PM | #35 |
Today's pennies are zinc with a very thin copper plating, so you'd be better off with a thin piece of copper stock from the hardware store. I'll stick with grease and graphite sprinkled on the grease.
