08-11-2010, 01:30 PM | #141 | |
Re: Boring a flathead
Vergil
Bigger fonts to aid in reading |
08-11-2010, 01:44 PM | #142 |
I did some Flow work on the modified port in my book and saw very little improvement over just shaping it similar to Mike Bishops work. I square up the side of the port nearest to the block eng leaving aprox. 1/4" gasket surface. What surprised me was how well the exhaust flowed in comparison to the intake. Well within the 80%.
08-11-2010, 01:54 PM | #143 | |
You are the man! Thanks. Tim |
08-11-2010, 02:14 PM | #144 | |
Ron that surprises me on the modified exhaust port shown in your book, I thought for sure it would show better flow than the results, good information. Tim these are the pictures I have, the first ones shows where the cut was and if you need the floor of the port thickness I can get that for you. The machining on the intake ports shown in the picture was an idea for a fuel injection setup that didn't happen. Vergil
08-11-2010, 02:17 PM | #145 |
tim ayers, i hope this is the view your`e looking for.
tom vergil is not only good, he`s FAST. Last edited by hotcoupe; 08-11-2010 at 02:25 PM. Reason: additional info |
08-11-2010, 02:20 PM | #146 |
Much better picture Tom, thanks and will now add it to my pictures. Vergil
08-11-2010, 04:14 PM | #147 |
Hot Coupe & Vergil:
Thank you very much. I better step away from the grinder before I hit water. I didn't think it was that thin there. As 'Ol Ron and cam grinder Pete say, "You got to build a few to learn a lot." (or something like that) |
08-11-2010, 08:06 PM | #148 |
I fully agree with Bruce, Ol Ron and others that the exhaust ports are not the problem some folks have professed. I was quite suprised at the smoothness of the internal exhaust passages from the factory. Henry did a good job, except at the end port exit; but that area can be filled either with a metal insert, or better, with a high-temp moldable material. Then ground, smoothed, etc. Tim, don't worry about the back pressure. You don't want any and anyone who tells you otherwise is blowing smoke.
Jim |
08-12-2010, 09:06 AM | #149 |
Thanks Virgil and tom for your pictures. I've never seen this much detail of the castings. In my book I moved the end exhaust to eliminate the exit bend, and was disappointed in the results. Some builders have suggested that because the exhaust is expelled under pressure the flow bench isn't the right tool to measure the difference. I will find some pictures of the ports I use in my street engines not sure how well they work either. The older I get the less I know.
08-12-2010, 07:36 PM | #150 |
I can email a photo of the port to someone that can post it. My email add is ron [email protected]
08-12-2010, 07:47 PM | #151 | |
Vergil
08-12-2010, 09:24 PM | #152 |
Didn't get it.
[email protected] Try again, I can send you several pics of things we've done. Some work some don't. |
08-12-2010, 09:40 PM | #153 | |
Email sent. Vergil
08-12-2010, 10:28 PM | #154 |
Heh heh... join the club.... |
08-12-2010, 10:37 PM | #155 |
Ron sent me a picture of the exhaust port after it was modified so will share it, nice work Ron.
Vergil
11-21-2011, 11:20 PM | #156 |
I think some of the new folks might enjoy this old thread,Craig.
" When I was a boy of fourteen, my father was so ignorant I could hardly stand to have the old man around. But when I got to be twenty-one, I was astonished at how much he had learned " Mark Twain. |
11-22-2011, 07:31 AM | #157 |
used to run a 3 7/16 x 4 flatmotor @ Sanford Maine back in the mid 50's, always wondered if i met Walt at one of these meets-- i had purchsed the block from a fellow named Garvin Cooper @ new england speed--he used to run @ Norwood Arena.
11-22-2011, 07:44 AM | #158 |
One of the best threads on the Ford Barn in my opinion. Love to learn from the Masters. In fact I always thought it would be so cool to have a Flathead "Summit" where the best of the best could gather in one place and share knowledge and experience. I could envision cool seminars covering subjects like porting and camshaft design. How about cracked block repair? Flathead trivia games and such. Maybe a little dyno flogging to put theory to the test. I really think this could be a great thing.
11-22-2011, 07:50 AM | #159 | |
I have an 8BA block that is bored to 3 7/16". The pistons are cast and they are for the 3 3/4" stroke. That's about 275 cubes the hard way. The block is in tough shape though, gonna take some TLC to bring her back to life. |
11-22-2011, 10:14 AM | #160 |
So I've got an extra 8BA block that's bored to .125 over(3.312) with one cyl sleeved, Can it be safely bored more? I know that every one recommends "sonic testing" but I don't think anyone here can do that.
When you say "sonic" here, the guy says "Bring me back one of those footlong hotdogs while your there". |
